Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 01-03-2019, 10:25 AM
LAlexander LAlexander is offline
Default Exported tracks lose volume settings?
Hey guys :)
I'm having a bit of trouble getting stems to export while maintaining the level balance they had in the session. For some reason when I do this then re-import them into protools they're all out of whack. 'Perserve volume and automation' setting is ticked. Any ideas?
Cheers
LA
Old 01-03-2019, 10:41 AM
amagras amagras is offline
Default Re: Exported tracks lose volume settings?
Make sure all your tracks are using the same output channel
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 01-03-2019, 10:50 AM
Thanks mate - so should I route all my tracks and buses to a pre-master bus?
Old 01-03-2019, 11:35 AM
Wherever you want as long as all of them end up in the same place
amagrasmusic.com
Old 01-03-2019, 03:46 PM
The Weed's Avatar
The Weed The Weed is offline
Exporting files does just that, export the raw audio, no real-time plug-ins, volume automation, etc. will be included. Are you exporting or bouncing out?
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Low volume output on exported audio files (.wav, .mp3) created on ProTools 11 Softwar Mac007 Pro Tools 11 1 04-20-2015 06:05 AM
Exported and recorded audio volume is too low joelmbeck Pro Tools SE and Essential (Win) 0 07-26-2014 07:11 PM
Exported Tracks Sound Softer Josh16 Getting Started 2 06-03-2014 07:13 PM
My exported "preset" I/O Settings Still Quirky. since 7.0 dkstudios Post - Surround - Video 0 03-09-2009 02:38 PM
lose of volume when i bounce mrluked 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-16-2004 01:22 AM
