Old 06-01-2002, 07:50 AM
esonus esonus is offline
Default Midi filter and Motu Micro express!!!!
Hi there;
I've recently left my old Mac and move to a PIV 1,7 keeping the whole setup, and after solving lots of configuration problems I'm facing now what I expect to be the last one...The only way I can keep Pro-Tools working with my Micro-express parallel interface, is filtering all midi stuff, except notes. If I don't do this, on the smallest movement with the pitch bend or wheel it immediatly crashes and I must startup the computer (in the details box of the error message I can see that it has something to do with the Motu drivers MOTUMX.DRV...). I downloaded the lattest Motu drivers from the Net several times but...nothing. On the other hand, the same interface worked fine on the Mac platform...Does this have to be with the parallel port connection?...Can someone help me?...I love "wheeling"!
Old 06-01-2002, 07:56 AM
Sixpence Sixpence is offline
Default Re: Midi filter and Motu Micro express!!!!
I had problems with a midiman Parallel device before....
The Parallel port on a pc can be setup a number of ways in the bios.. standard, bidirectional, enchanced etc... I'd say that it's not set properly and you'll need to try changing the way its set to each of the different options until it works...
Sean McC
Sixpence Studios
http://www.seanmccormack.com
Old 06-01-2002, 08:33 AM
Thanks for your advise, Sean...unfortunatly I forgot to mention that I've also tried to launched it on "Bi-directional" and after "EPP" mode, but the problem persisted!...
Old 06-01-2002, 05:13 PM
Bastiaan Bastiaan is offline
have you checked the motu-site? Maybe they have newer drivers for your stuff......with bugfixes....
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 06-01-2002, 05:17 PM
Vegadark Vegadark is offline
there is something about a positive voltage being sent on the lpt port. do a search for it. it may help you.
DIGI002R, PTLE8.0.5, Windows XP, Asus K8V SE Deluxe, AMD64 3000+ 1.5GB ram, ATI Radeon HD3xxx AGP, dual 19 inch LCD screens
Old 06-02-2002, 03:26 PM
Phil O'Keefe Phil O'Keefe is offline
I am sorry I don't know what's causing your problem, but my parallel port Micor Express is working with my Athlon XP system with no problems. I have my printer port set to LPT.
Phil O'Keefe
PT 2023.6 Ultimate (Perpetual) | Avid Carbon | M1 Max Mac Studio; 32 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura.
PT 2023.6 Studio (Perpetual) | M1 MacBook Air; 16 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura.
MIDI dropouts in PT 9 HD / MOTU Micro Express innerbooty MIDI 0 03-07-2013 01:21 PM
MOTU Micro Express question thornlab 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-31-2003 04:59 PM
USB MOTU Micro Express midi problems w/001 & DP 867 Mac: Help! fingerz88d 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-22-2003 08:04 PM
OMS won't detect my MOTU USB Micro Express gonzolagonda Digidesign Hardware & Software 0 10-06-2001 08:32 AM
MIDI Output to MOTU Micro Express rnygren 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-12-2001 06:54 AM
