Old 05-30-2003, 08:32 PM
thornlab thornlab is offline
Default MOTU Micro Express question
Hello all,
Just recently got the micro express and i tried hooking it up today,however,it came without drivers. I run 001 on 9.2.2 G4 400mhz with a "gearport"/don't know if i should call it a hub/, until yesterday was routing a Midiman Midisport without a problem. I needed more ins and out.I went to the MOTU website and of course every related driver was for OS X. I saw a driver for a thing called "ClockWorks 1.07 Console Only"
the only thing supported by OS 9...would that do the trick or i need something completely different? [img]images/icons/confused.gif[/img]
Old 05-31-2003, 03:02 AM
mik mik is offline
Default Re: MOTU Micro Express question
Hi thornlab,
I have the same setup as you, but with a "real" usb hub. My micro express works really great under os9 and osX.
For Os9, it came with a freemidi installer that you have to install to make your microexpress works under os9. Just check the Omscompatibility to "control" your freemidi setup under OMS. You should find that in the Motu website.
Clockworks also came with the microexpress and is some kind of remote wich let you map your midi ins and outs, put an offset if you use the MTC feature, etc..
You need both to make it works under Os9.
Hope this help.
Mk
Old 05-31-2003, 04:59 PM
KennyB KennyB is offline
I have had the Micro Express for 3 years, the drivers that came with it caused occasional "errors of type 2" with PT until a neighbour provided me with the driver I use now.
It might not be the most up to date but it works. I will email it to you.
MIDI dropouts in PT 9 HD / MOTU Micro Express innerbooty MIDI 0 03-07-2013 01:21 PM
MOTU Micro Express & Digi 002 Question sydphi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-13-2003 08:44 PM
Midi filter and Motu Micro express!!!! esonus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-02-2002 03:26 PM
OMS won't detect my MOTU USB Micro Express gonzolagonda Digidesign Hardware & Software 0 10-06-2001 08:32 AM
MIDI Output to MOTU Micro Express rnygren 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-12-2001 06:54 AM
