Old 03-06-2024, 04:52 AM
samplaire's Avatar
samplaire samplaire is offline
Default Timecode audio file synchronization
The scenario is like that - I have a video file which has a timecode in it so I can just spot it to a relevant position (no sound in it). I have 2 audio files (one with a dialog, second with the timecode but being audio and the timecode is what I want to read from that file) to accompany that video which are longer (but they both are of the same length) so I can't just start all of the 3 files to have them in sync. As I mentioned, one of the audio files are just timecode which is the correct timecode for the video file. Is there a way to place the file in timeline with the correct timecode which is printed in the audio? Then I could just place the second audio file in sync with the audio timecode file.
Mac Studio M1 Max 32/512, 2x 2TB 40Gbps + 2TB 10Gbps, 13.6.5, Logic 10.8.1, PT Ultimate 2024.3, Mackie Big Knob Studio+
Old 03-06-2024, 07:56 AM
samplaire's Avatar
Default Re: Timecode audio file synchronization
Ok, I've found an app suitable to do it - LTConvert. I've got a problem with it however - after converting a file (ie printing a new timecode into it) the old timecode shows up in Pro Tools. When I open the converted file back in LTConvert the timecode is the new one (unfortunatelly iMediaHUD doesn't work on a silicon Mac so I can't check its data the old way)
Old 03-10-2024, 02:04 PM
alexbooy alexbooy is offline
Hi I found out the same issue. But when checking the file in LTC convert, you can read the new TC, so you can manually place the file in the ProTools timeline.
Old 03-10-2024, 02:08 PM
samplaire's Avatar
Thanks for your help! I will get hudrets of files though… easy to make a mistake…
Old 03-11-2024, 01:44 AM
Originally Posted by samplaire View Post
Sounds like your location crew need to rethink their setup. People are still recording LTC to audio tracks these days? If the original picture has TC why can't they just jam sync the audio recorder? Instead they chose to give you a hard time syncing all that up? Should they not do that in the cutting room and just give you an AAF since there's only one audio track anyway?
Maybe this helps? https://tentaclesync.com/sync-studio
Old 03-12-2024, 12:23 PM
In case of so many Tc files. I would ask an editor with Media Composer to batch convert these files, reading the aux tc and convert it into the wav’s metadata.
HTML code is On
Importing Video file with TimeCode Spyderrp7 Post - Surround - Video 4 06-26-2020 05:47 AM
Audio Video synchronization grateful 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-17-2011 05:22 PM
Conform audio (with different timecode) to EDL tom_lowe Post - Surround - Video 5 10-02-2010 06:26 AM
Export timecode in text file :Rob: 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-11-2009 07:29 PM
Video and audio out of synchronization in loop rec HHHieu Post - Surround - Video 9 12-09-2004 08:46 PM
