Old 02-28-2024, 06:00 AM
Cheesehead Cheesehead is offline
Default Calculating Waveform Overviews?
I'm currently working with a very large super-session and when I import new media PT doesn't show any waveform in the clips. If I go to the task manager window I can see calculating waveform overview is spinning and apparently stuck.
If I pause the process all is fine and I can keep working and when I re-open the session all the waveforms are there.
If I don't pause it and leave it spinning PT will sometimes do a hard crash and bomb out completely.
I've read the other threads on this, but there was no conclusive solution and wondered if anyone else had found what the issue is?
Thanks
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
Old 02-28-2024, 06:44 AM
smurfyou smurfyou is offline
Default Re: Calculating Waveform Overviews?
Delete the wavecache file and see if that clears up the jam.
~Will
Old 02-28-2024, 06:45 AM
Oh and are you pulling from a network drive?
~Will
Old 02-28-2024, 09:11 AM
No network, it's an NVme SSD inside the mac pro.
I'll try deleting the cache, but it worries me it will just crash it?
Old 02-28-2024, 01:47 PM
Shouldn't crash it, just force PT to recalculate. From an SSD it usually flies.
You can always just stash it on the desktop if you don't want to delete.
~Will
Old 03-02-2024, 02:37 AM
I deleted the cache and it seemed to improve for a while, but now it's back to getting stuck again.
The only ways I've found to unfreeze it are re booting PT and sometimes if I import a new piece of audio via audio import or through Soundminer it will wake it up.
HTML code is On
Always Calculating Waverform Overviews composergarrett Pro Tools 12 15 07-23-2017 02:15 PM
Calculating Waveform Overviews.... forever?! davedotpez Post - Surround - Video 2 07-09-2015 06:01 PM
Calculating Overviews p**ing me off! KMcK macOS 10 09-02-2013 05:39 PM
PT10 : Calculating Overviews midnightrambler Pro Tools HDX & HD Native Systems (Mac) 3 08-10-2012 06:56 AM
Calculating overviews when loading stevegalante Pro Tools TDM Systems (Mac) 1 04-22-2000 09:32 AM
