Old 02-27-2024, 11:29 AM
Riinehart Riinehart is offline
Default Field Recorder Workflow -- No Metadata, Timecode Only
Hi all,
I'm decently familiar with FRW, but currently working on a feature and have a problem, completely unable to match anything with FRW to my original production audio tracks.
Some context: The files were transcoded by the DIT in DaVinci, then sent to the picture editor who's using Premiere Pro.
Somewhere along the way, the files have lost all metadata. They still have timecode, but nothing else. File names are different, nothing else matches.
I've just downloaded a trial of Ediload to see if I can find some workaround and get them to match up, but so far no luck with that either.
Screenshot attached (hopefully, if it works) to give an idea of what I'm seeing in Ediload.
Has anyone run into a situation like this? Any ideas on what I can try?
Or is there something different I can request from the DIT or picture editor, if it's not too late at this point?
Any help/ideas much appreciated!
Edit: Hopefully this link works for the image: https://ibb.co/wLk29J3
Old 02-28-2024, 03:30 AM
mfranken's Avatar
mfranken mfranken is offline
Sounds In Sync
Default Re: Field Recorder Workflow -- No Metadata, Timecode Only
Thanks for sending your 'Save Support' zip file to me earlier today. I've sent you a reply showing how to match these events by extracting the scene and take numbers from the clip names.
Best regards,
Mark
Mark Franken, MPSE
Dialogue editor/supervisor IMDb
Creator of 'EDI' applications for sound post editors
www.soundsinsync.com
Old 02-28-2024, 06:38 AM
smurfyou smurfyou is offline
I would guess this happened in Premiere whilst syncing the sound.
~Will
Old 02-28-2024, 08:23 AM
Best regards,
Mark
Thanks, Mark -- diving into this now!
Old 02-28-2024, 08:25 AM
Thanks, Will. Any idea how it could be avoided in the future, or anything I can suggest to the picture editor that would help retain the metadata?
Old 02-28-2024, 02:49 PM
You'd first have to ask if they used Merge Clips to sync. That is a bad idea.
Usually if they sync via Multicam Clips it should retain the sound metadata.
Your filenames look like the usual Premiere renamed files though. It would be a good question for the Assistant Editor if they saw the metadata in the original WAV files before syncing. Need to figure out at what point it was lost.
~Will
Old 02-28-2024, 04:37 PM
mfranken's Avatar
Sounds In Sync
I would also be having a word to the sound recordist as looking at your screen shot they haven't embedded useful Sound Roll or Scene Number data in the location WAVs. If the scene number in the WAV metadata contained just the scene number, it would be a lot easier to link the WAVs to the scene and take number in the edit list which you can extract from the XML clip name.
Mark Franken, MPSE
HTML code is On
Field Recorder Workflow with Live PT sessions as Field Recordings SlickSlack Post - Surround - Video 9 11-10-2022 05:45 AM
Timecode mismatch - Field Recorder Workflow glessard Post - Surround - Video 5 11-24-2014 01:24 PM
Field Recorder Workflow pls help! jahtao Post - Surround - Video 4 03-27-2014 05:04 PM
Field Recorder Workflow & PT 9.0.2 Tom Graham Post - Surround - Video 8 03-20-2011 11:39 AM
