Old 02-15-2024, 12:35 PM
KungFuLio KungFuLio is offline
Default HDX AES/EBU output.
I have seen a few HDX interfaces without any I/O cards at a reasonable price. On these units, it the AES/EBU I/O still active? I would like to use the digital I/O as an output to a grace m905 monitor system. I am using a Lynx Aurora as my A/D D/A but I'd like my monitoring chain not to leave the digital domain until it reaches the Grace.
I'm on a 2019 MacPro with one HD card.
Thanks for your thoughts!
Mac Pro 2019
OS Monterey
3.2GHz 16 core intel Xeon W
96GB Memory
Old 02-15-2024, 01:32 PM
Default Re: HDX AES/EBU output.
Being clear with descriptions and exact product names would help.
Why is "HDX" in the title and body here? You mean an Avid HD I/O box with no I/O cards installed in it? There is nothing specific in any Digilink interface box about HDX.
You have a Lynx Aurora connected via Digilink to an Avid HD Native card? What exact model Aurora (8? 16? or Aurora (n)?). The Aurora 8/16 have AES/EBU on them,... is that all already in use? Or do you have an Aurora (n)? And if you have an Aura (n) 16x16 analog why not just add an LM-DIG card? And config of an Aurora (n) matters here to know if you have any more downstream Digilink capacity to add other I/O boxes.
I *think* that a HD I/O chassis might work with chassis I/O only and no I/O cards installed but am not totally sure. Maybe others will know, but if you had to go to a HD I/O box you could always pick up one with I/O card in it. All this stuff is cheap and only getting cheaper as the Digilink ecosystem dies. But why that is interesting to get AES/EBU at all is not clear given you have some form of Lynx Aurora/Aurora (n) box.
Old 02-15-2024, 09:48 PM
Sorry... HDX system. Aurora (n) 16/16 as A/D D/A (no AES/EBU) that connects to the computer via digilink. I'm considering an Avid HD I/O with no cards installed for the sole purpose of using the AES/EBU digital output to a Grace m905 for monitoring.
I hope that's a clearer description of what I'm attempting to do.
Mac Pro 2019
OS Monterey
96GB Memory
Old 02-15-2024, 10:17 PM
Gotcha, thanks.
Then I would just get a LM-DIG AES/EBU card for your Auroa (n). Simple integrated, known to work, lots more connectivity for other uses in futures, not expensive, no fan, no wasted rack space, no old past sale life Avid hardware, and it gives you the option of adding an ADAT module on top of this.
https://vintageking.com/lynx-studio-...aes-i-o-module
And since you have a HDX card then you have two master Digilink ports so configuring the Aurora (n) with the LM-DIG will eat all the connectivity on one DigiLink port bit still leaves you with the other port.
Auto-assign my Output to a missing output from another producer's project? Rockman413 Pro Tools 2020 4 05-29-2020 06:44 PM
No output device selected in Studio Monitor Express, using Default Output (Mbox Pro). Focuret 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-12-2014 07:33 AM
Whats the Difference between Bounce to Disk Source -> Physical Output vs -> Output Epik Productions Pro Tools TDM Systems (Mac) 8 05-03-2013 12:48 PM
No headphone jack output - Meters showing output Hotcrazyfruit Eleven Rack 6 05-06-2012 12:09 PM
Eleven Rack: Headphone Output Impedance & Amp Output Tech Specs MR290378 Eleven Rack 12 11-29-2011 05:10 PM
