Old 02-10-2024, 08:43 PM
chadlittle73 chadlittle73 is offline
Default Pro Tools not recognizing my inputs
I record my church services onto my laptop from the wing interface. I have had no problem, until last week I plugged in the USB, opened a protools session, and couldn't record enable any tracks. The Playback engine is set to wing, and when I go the i/o setup in protools, the outputs are correct, but the inputs are set for my mixing interface at home. When I delete these and try to default them, it will not recognize the wing setup. I also tried to create new paths, but it will not allow this either. HELP.
Old 02-11-2024, 06:10 AM
its2loud its2loud is offline
Default Re: Pro Tools not recognizing my inputs
Welcome to the forum.
This could be so many things. Posting some pics and system specs would be helpful to start.
This is a good place to start as well.
https://duc.avid.com/showthread.php?t=300050
Old 02-11-2024, 06:47 AM
tope d's Avatar
tope d tope d is offline
Hi!
Is there a way where we can see your hardware’s routing? Can you also check your playback engine if it’s set to your hardware?
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
PT First isn't recognizing all inputs from interface Vacis Pro Tools 3 09-21-2021 01:30 PM
PT 11 not recognizing RME inputs 1&2 (Windows 10) Samba Windows 7 02-14-2017 06:14 PM
Recognizing all inputs on Digi 002 JesseBroadcast 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-09-2012 04:09 PM
protools not recognizing all 8 inputs on my digirack 003+ hanagan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-21-2010 10:21 AM
PT Only Recognizing Inputs 1-2! Please help Alexrkstr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 12-06-2009 09:35 AM
