I/O Setup Crashing Pro Tools
Hello all,
I'm trying to integrate a second Avid interface in to my HD Native setup. There is something sync related that is crashing Pro Tools when I try to open the I/O settings. I'm at the end of my rope here, any help would be appreciated. System: Mac Studio M2 13.6.4 / Pro Tools 2023.12.1 w/ HD driver of same version / HD Native PCIe in thunderbolt 2 chassis / HD Omni / HD I/O. Current setup: Digilink port 1 of HD Native card hooked up to primary digilnk port on HD I/O. Digilink port 2 of HD Native card hooked up to primary digilnk port on HD Omni. Loop sync in to out, and out to in HD I/O to Omni. Pro Tools recognizes both interfaces. The HD I/O front panel shows it is using internal clock, is the loop master, and the Omni's front panel is set to loop sync. This is all as it should be. One interface at a time will work as usual. When I try to use both synced together, the I/O setup crashes Pro Tools upon opening. Things I have tried: -Trashing all preferences. -Uninstalling and re installing PT and the HD driver. -Installing older versions of PT and HD drivers going back to 2023.3. -Allowing PT full disk access. |
Re: I/O Setup Crashing Pro Tools
Hi SaschaP,
I was about to create a case for you, but it looks like you're using a different account for your MyAvid. Can you email me at [email protected] regarding this concern together with your system id so I can coordinate this to our technical support team?
Regards, Charles ________________ To create an Avid Support Case, you may go to https://www.avid.com/learn-and-support/contact-audio-and-music-support |
Hi Charles,
I appreciate your help. I ended up trouble shooting it down to the Omni causing the problem. At some point I noticed the "Monitor" scribble strip showed the control room volume as CR-INF in red, which is not normal. A front panel hard reset of the Omni seems to have fixed the issue. I will update this thread if things go out of wack again. Thanks. |
That's great news! Yes, please keep us posted here if you need further assistance.
PT crashing when click setup---I/O | jmp72 | Pro Tools HDX & HD Native Systems (Mac) | 4 | 04-29-2021 07:42 AM |
PT10HD crashing when selecting I/O Setup or loading session | jeffinaustin | Pro Tools HDX & HD Native Systems (Mac) | 3 | 07-19-2014 05:31 PM |
MIDI SETUP takes long to SETUP and doesnt SETUP | DartagnanSosa87 | MIDI | 3 | 01-28-2013 12:02 PM |
I need A new Setup for PT my computer keeps crashing! | gmorey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 04-09-2009 09:12 AM |
pb g4 15inch aluminum/mbox - setup issues/crashing | Bryan Cook | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 12-29-2003 10:01 PM |
