Old 10-03-2020, 03:56 PM
tripstation tripstation is offline
Default Tdm plugins hanging PT 10
Vss3 and Fairchild 670 hang PT10 Win 10 64 on startup but Virus Indigo for example loads and runs fine.
Anyone had this problem?
Sent from my J8110 using Tapatalk
ProTools 12 HD
Pro Tools 10 HD3
Nuendo 11
Ableton 9
Avid Omni HD
Avid 8*8*8 HD X 2
D-Control ES 32 Channel
Native Instruments Maschine Studio
TC Electronic PowerCore *2
UAD-2
Universal Audio 1176 LN
Universal Audio 2-LA-2
Universal Audio 2-610
Neve DPX
Supermicro X10DAI Dual Xeon E5 v4 Win 10 64 128GB Ram
Old 11-29-2020, 04:19 PM
Default Re: Tdm plugins hanging PT 10
Could be that PT 10 is not compatible with Windows 10. Or maybe those plugins are not compatible. If you need them, maybe check what version of each is in your rig and see if the maker has other(older or newer) versions that you can try. Personally, I gave up on the dual install quite a while ago. If I need PT10, I swap out my system drive for an older setup with windows 7.
Old 11-29-2020, 06:52 PM
JFreak's Avatar
JFreak JFreak is offline
Compatibility info here.
Janne
Old 02-06-2021, 03:46 AM
Suad Cokljat's Avatar
Suad Cokljat Suad Cokljat is offline
Hi. I think this is more about incompatibility of PTHD10 and certain TDM plugins than compatibility of PTHD10 and Win10. I've seen some users here on DUC are using HD10 on Win10 without issues.
I have the same problem with some TDM plugins on Win7 - McDSP and URS make HD10 hang on startup. However, Autotune 5, Waves, Brainworx and SPL TDMs all work fine on PT HD10.3.10.
I was interested in Eventide Anthology II TDM and asked their support for compatibility info. Their reply is - "If it is a version earlier than 10.3.6, then it should work. Anything after and including that version will not work." On my question "why" they replied - I don't have the exact reason why A2 won't work with those versions, but it won't work. I assume there were changes made to the code that will prevent it from working. The timing also coincides with our shift to offering only native plug-ins in the AAX, AU and VST formats.
AVIDs compatibility list says Anthology II version 1.5.1 works on HD10 but not specified what PT subversion this includes. When you dig through and carefully study online information and documentation related to the old TDM/RTAS plugins from the transition time Digidesign - AVID, there is a lot of ambiguity, illogicality and contradictions...
https://avid.secure.force.com/pkb/ar...ity/en343311#E
Hope this helps...
Cheers!
S
Old 02-06-2021, 03:48 AM
JFreak's Avatar
"without issues" does not mean some other system does not have any. PT10 was last supported on Win7 so using it on Win10 is really pushing it far beyond limits
Janne
Old 02-06-2021, 04:08 AM
Yes, I agree with you 100%. I would not recommend going HD10 and Win10 unless absolutely inevitable. My point in this case - some other TDM plugins also make HD10 hang exactly as described in initial post even on Win7 x64.
Cheers!
S
Old 02-06-2021, 04:09 AM
JFreak's Avatar
Need to be SP1 though
Janne
Old 02-06-2021, 04:17 AM
Of course it's Win7 SP1
Cheers!
S
Old 02-10-2021, 09:38 AM
This will maybe help you with your problem:
http://duc.avid.com/showthread.php?t=412188
I seem to have been wrong not doubting win10.
Cheers,
S
Old 04-02-2021, 10:13 AM
I've been having more success in Win 10 64 version 1703 (os build 15063.1387)
All plugins seem to load fine.
It does seem to freeze the pc when you quit Pro tools though.
Workaround so far is to save and quit from the task manager.
ProTools 12 HD
Pro Tools 10 HD3
Nuendo 11
Ableton 9
Avid Omni HD
Avid 8*8*8 HD X 2
UAD-2
Neve DPX
Hanging/Freezing when putting plugins on tracks ffud Pro Tools 11 1 03-12-2015 01:42 PM
7.3 "hanging up" Anyone else? ronwasserman Pro Tools TDM Systems (Mac) 4 12-18-2006 07:06 AM
Pro Tools hanging on startup at "Loading Plugins" Eric Gale 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-03-2006 06:35 AM
