Old 11-17-2018, 05:44 AM
ChuckS ChuckS is offline
Default Re: Xpand2 playing on separate midi tracks...help!
In MIDI Preferences, what do you have selected for the Default Thru Instrument?
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 11-17-2018, 09:52 AM
Ianoh's Avatar
Ianoh Ianoh is offline
hi Jeffro, I couldnt upload the screen recording to avid for some reason but I uploaded it to youtube if you want to look at it there, ill leave the link here...
https://youtu.be/tt3qCRnJkV0
Old 11-17-2018, 09:54 AM
Ianoh's Avatar
Hi Chucks, I've just checked midi preferences and the default thru instrument is expand2 1-1.
Should I change this ?
Old 11-17-2018, 10:55 AM
Yes, change it to first selected MIDI track.
Old 11-17-2018, 11:24 AM
babaorum babaorum is offline
It works as expected here, for each 4 midi tracks I have my keyboards as 'all channels' in input of the midi tracks is it the case for you ? because I have tried with midi 1 for track 1 , midi 2 in input for track 2 etc ... and it didn't work.
Pro Tools 2024.3 - Cubase pro 113 64bits- Windows 10 pro 64bits - wavelab 12 pro - core i9 9900K - 32 Go RAM All SSD- interface : ANTELOPE ORION Synergy Core.
Ideal-Sound Not_To_Flow
  #16
Old 11-17-2018, 12:05 PM
When you assign the MIDI input like this you have to physically change the MIDI channel on the controller for this to work. Much easier to select 'All' or if you need/want to pick a specific device listed in predefined, easier to select 'All Channels'.
  #17
Old 11-17-2018, 12:45 PM
jeffro's Avatar
jeffro jeffro is offline
Thanks for the screen recording.
Real-time MIDI will be affected by the Default Thru Instrument pref, so having this set to "Xpand2 1-1" means that a keyboard (in the MIDI editor or an external controller) will pass notes through to MIDI ch1 of the first instance of Xpand2. Best to set this to "None" so that Rec enabling a track controls this, or "Follows First Selected MIDI Track" then select (highlight) the track (name) you are working on.
Can you confirm that you played the session I provided (not just clicked on the MIDI Editor's Keyboard) and that it didn't trigger all 4 parts?
linkedin
  #18
Old 11-17-2018, 12:58 PM
Ianoh's Avatar
ok I've just finished thrashing pro tools and restarted it....but the problem persists. I think I might try downloading pro tools 2018.7 and see how I get on with that
  #19
Old 11-17-2018, 01:00 PM
jeffro's Avatar
2018.7 shouldn't behave any differently so I wouldn't recommend that.
Did my session play correctly? (Actually playing the session, not just clicking on the keyboard.)
linkedin
  #20
Old 11-17-2018, 01:10 PM
jeffro's Avatar
Your video shows you have the "Inst 1" track selected in the MIDI Editor (black dot to the left of it in the upper left under Tracks), and it's likely set to ch1. Try changing that to the MIDI track you want the Editor's keyboard to control.
linkedin
Xpand2 multiple instruments midi volume lvsranch Virtual Instruments 11 03-12-2015 03:48 PM
Clarification: Can I separate MIDI drum instruments recorded on one track ssdyer Pro Tools SE and Essential (Win) 0 12-15-2011 05:31 PM
Trouble record armed track jamming to playing existing tracks? Gravy macOS 5 11-29-2011 02:58 AM
Native Instruments Playing through unreleated Audio Tracks!!! rockonswitch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 04-15-2010 06:55 PM
Recording instruments on separate tracks 4rm keybo JGutta Tips & Tricks 2 05-08-2005 02:31 PM
