Old 06-22-2016, 11:39 AM
tundra
Guest
Posts: n/a
Default Pans on S6 not working, Pans in GUI work correctly [SOLVED]
Probably just a checkbox they are missing.
But anyone know why the pans on the S6 would just snap back and not do anything, while the pans in the GUI work fine?
Old 06-22-2016, 05:46 PM
EddieJones's Avatar
Default Re: Pans
Sounds like a connection issue, try dragging the workstation out of the connected list and back.
Are you using the internal DHCP server or an external one ?
Old 06-23-2016, 06:00 AM
tundra
Guest
Posts: n/a
Default Re: Pans
Tried that. even restarted the WScontrol App.
All internal.
Thats why I am thinking its a preference or setting somewhere that needs to be flipped.
PT GUI pans were fine, panning with the pucks on the Touchscreen was fine, but the knobs on the S6 would not function.
Old 06-23-2016, 09:08 AM
EddieJones's Avatar
Default Re: Pans
These use 2 completely different methods of communication so I can understand why one works and not the other.
Are you using the internal or external DHCP ?
Old 06-23-2016, 12:01 PM
tundra
Guest
Posts: n/a
Default Re: Pans
Originally Posted by tundra View Post
All internal.
It may have been the users session.
Because it it no longer an issue.
Pans not working postdigital macOS 5 06-21-2011 07:14 AM
link aux pans to main pans JZStephan Pro Tools TDM Systems (Mac) 2 11-24-2008 06:46 PM
STRIKE - WHY ARE PANS NOT WORKING?????? Jim Casey Virtual Instruments 3 04-09-2007 03:29 PM
Send pans follow channel pans? woodshopsound Pro Tools TDM Systems (Mac) 2 10-14-2004 01:36 PM
Gettin Pans to Work SamuelAdams 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-18-2004 05:58 AM
