Old 10-11-2016, 06:27 PM
gtomassetti's Avatar
gtomassetti gtomassetti is offline
Default Re: How to make Omni HD play Mac sounds??
[QUOTE…Hope this helps some...[/QUOTE]
BRILLIANT! It worked on the first try.
My MH is definitely having issues. I'll be sending it to them before long, and to add insult to injury, my beloved, 22-year-old Ensoniq TS-12 has suddenly stopped sending audio out of the right output. (At least I can get that taken care of locally.)
But with this fix, I can run iTunes, YouTube, etc. right through the OMNI with no issues. Thanks so much!
Cheers,
Gary
Mac Pro 6,1 ("Garbage can"), late 2013, 3 GHz 8-Core Intel Xeon E5; 64GB RAM; MH ULN-2 (Ethernet MHLink connection)
PT Ultimate 20.12.0; REAPER64; PreSonus Studio One 5 Pro, Central Station Plus, and FaderPort
McDSP All Access; Slate Digital All Access; Waves Diamond 12.0; NI Komplete; EW GhostWriter
Finale 26.3.1
Old 05-14-2017, 01:43 AM
xexina xexina is offline
Default I have the same issue with Windows
Hey guys
HD native and Omni are working perfectly and I have no issue working in PT 12.5. but as you all know , we cant use it in any win to hear the system sound.
so I used my optical Outout on my onboard sound card and connected it to the Omni optical in .... I can see the frequencies on the Omni Monitor , But when I change it to output , I don't see anything and I cant hear anything as well . is there anything special that i have to do , or do i have to change any setting inside Omni ...or anything else you guys may think of and I haven't thought of it...please help me out here
Thanks
XeX
Old 01-04-2021, 11:16 AM
Bruce Barker Bruce Barker is offline
This thread's gathering some dust, but I figured I'd do a quick post to help round out the options: my OMNI HD is typically setup for 5.1 mixing, but I need to do occasional non-Pro Tools stereo monitoring on this same machine. I tried using the optical/TOSLINK solution (Mac out to OMNI in) but could not get audio. Clock source issue, maybe? Other than basic cables, I didn't have enough extra equipment to test things further, so I switched gears and went for the analog solution (Mac 1/8" out to OMNI TRS 1 & 2. That config only got me Left channel audio, as reported by another user here. Absolutely NO clue as to what caused that issue, and no luck adjusting Hardware or I/O paths to get the Right channel working. So... I routed the analog signal to the OMNI TRS 3 & 4 inputs, and it worked perfectly! Why 3 & 4 passed stereo audio while 1 & 2 didn't remains a mystery, but I'm up and running, so just thought I'd pass along this potential workaround.
Old 01-05-2021, 01:34 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Hey Bruce. I have 2 OMNIs with busted mic pre for 1 & 2. This might sadly be the case for you. However, regarding your optical for monitoring, that should be an easy fix. Go to hardware, must have a Monitor set up (for your 5.1). You could set up your down mix options from there, too. Then, go to your Mixer tab. You'll see Optical (S/PDIF) there. If it says ADAT, you need to change your settings on your "Main" tab, under "Digital 1-2 Input Format: Optical (S/PDIF).
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Anyone figure out how to play system sounds through HD Omni? agershon Pro Tools HDX & HD Native Systems (Mac) 46 05-09-2018 11:24 PM
Avid Omni spdif In sounds much better in 96k mmk Pro Tools HDX & HD Native Systems (Mac) 9 09-26-2015 07:21 AM
Can we make some noise so Avid can release an HD Omni firm update... deejay2x Pro Tools HDX & HD Native Systems (Mac) 14 09-16-2014 04:04 AM
Pro TOols playback is OK, system sounds and other sounds won't play bimple Windows 1 08-24-2011 05:14 PM
Help! I need to make a 5:1 mix to play on DVD! johnnyv Pro Tools TDM Systems (Mac) 3 03-25-2003 08:43 PM
