  #21
Old 03-21-2016, 04:44 PM
newfuturevintage newfuturevintage is offline
Default Re: PT 10.3.10 on Win7 + UAD-2 problems
Originally Posted by jeam25 View Post
wow...did you said to have installed the lastest audio card drivers ? ( RME )
Likely. I updated about a week or two ago. With those guys though, it's possible there's a new one. Version I'm running is from Feb. 5 of this year...
...just checked, yes, this is the current version.
  #22
Old 03-21-2016, 05:20 PM
jeam25's Avatar
jeam25 jeam25 is offline
ok try changing the DEP on windows .
always on , always off etc. see if makes a change .
http://www.thewindowsclub.com/disabl...ion-prevention
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
  #23
Old 03-21-2016, 06:56 PM
Thanks, I'll give that a try.
The video card driver change has been a huge help so far. I've only had the one crash described above in almost 5 hours of runtime. Current uptime is 3 hours, all but maybe 5 or 10 minutes has been active mixing and/or tracking.
Nicely, the last crash didn't totally bork the session I was working on. Reboot, begin mixing again (to a session copy, naturally).
Again, thanks for all the help, it's been great to have a sounding board that's been there!
edit: I also disabled "extra buffering" and enabled "CPU optimization" in the UAD control panel after the last crash.
  #24
Old 03-21-2016, 07:23 PM
jeam25's Avatar
Ive been there ..so im glad its better ... yes the extra buffering off helps sometimes...you might want to disable the " Enable CPU optimization " on UA control panel too as is suggested by them to run with Protools .
Protools Ultimate
  #25
Old 03-24-2016, 04:33 PM
Will make this happen...I'd actually done that and been running that way for a long time, but was just so fed up I enabled it to try something.
I think the video card driver is the most likely suspect. Of all the things tried, this has made the biggest impact. Was able to open formerly 'bad' sessions, and have about 8 hours of mixtime on sessions that were problematic in the past with only one crash so far.
Only new thing that's cropped up was a distorted bounce-to-disk mix. The session played perfectly when not bouncing (all conversions set to 'after bounce'), but was distorted on bounce. Relaunching PT cleared it up.
Last thing if anyone has a quick answer: about 50-60% of the time when I bounce, the count-down meter comes up, mix begins, the screen quickly flashes once, then the count-down stops.
When this happens, I can't ESC or ctrl+. abort the mix. Gotta wait until it finishes. The mix is clean, and it will finish correctly, I just can't cancel if I hear something I want to change. Any ideas?
Thanks!
Win7 SP1 / PT 10.3.2 Install Problems Hendrik XIX Windows 2 02-18-2013 06:15 AM
Installation problems - win7 danny1990 Pro Tools SE and Essential (Win) 0 08-07-2010 11:37 AM
pro tools LE 8.0.3 problems with win7 kevin masl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-25-2010 04:36 PM
pro tools LE 8.0.3 problems with win7 kevin masl Pro Tools M-Powered (Win) 2 01-25-2010 12:29 PM
PT8 Win7 problems St.BeesJevans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-15-2009 12:50 PM
