Xpand2 multiple instruments midi volume
Hello, I am having a problem with volume control from the channel 3 midi instrument in xpand2 affecting channel 1 and 2 when I have 3 instruments on 1 instance of Xpand. I have looked for odd outputs in the event list and nothing. Just hoping there might be a setting I am not tweaking correctly. Any advice would be helpful.
Re: Xpand2 multiple instruments midi volume
If you change MIDI channels does the problem follow?
Yes, I have tried different channels, but when I do a volume change on the third or fourth instrument it mutes the first and second until I change them again. Most odd.
That is odd. What are you automating? I think there's a MIDI CC number, OR volume automation. I wonder if you're automating the volume of the plug in, instead of changing the individual MIDI channel?
On the plug-in, you can select which parameters are "automate-able". You should be able to select the volume of the third instrument from there. Then in the Edit page drop down menu, and can view (and edit) that automation. Sorry... I'm not in the studio so I'm trying to do this from memory. I hope it helps |
Been a long day - but I think this was the Tip:
Instead of creating MIDI tracks for XPand!2, create Instrument tracks. That gives you audio and MIDI on each track. Give each track its own MIDI channel (channels 1 to 4).
Pro Tools Studio 2024.3 * Studio One Pro 6.6 * Harrison Mixbus 10 Pro * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 & Air 32 MINI * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock * 3 TB Samsung SSDs * 3 Screens: 15.6” Laptop & 24” BENQ LED GL2450-B & Samsung 27” CT550 curved Monitor |
Thanks for the reply. I was hopeful but still the midi volume control seems to be jumping ship on the various channels once it gets past the first two instruments. Doing the same thing even in an instrument channel. This seems to be a bug. Currently I am just not using xpand in this way.
Okay, after playing with this in several different setups, it seems that the midi controllers are being latched on to by the first instrument to see them. In other words the midi notes are going to their assigned instrument on xpand but the controllers are not being treated channel specific and are just controlling one of the available instruments at random. I may try to assign control to the level fader on xpand but, once again, if anybody knows a setting I am neglecting please let me know.
This is a limitation with MIDI Volume in Xpand (MIDI Volume affect the main volume knob/setting, not the Parts), and was discussed previously at http://duc.avid.com/showthread.php?t=354513
I didn't see this or any workaround (like using controllers 20-23, which are the defaults for the Part Volumes) listed in the knowledge base so I'll add it.
• linkedin •
Russ (2011) to the rescue... again!
AIR Xpand 2 - How To Control Volume On Each Part http://www.pro-tools-expert.com/xpan...each-part.html Hope this gets you there.
Control Automation with Encoder – set to 4 Encoders to CC111, CC112, CC113, CC114. Right-click on any LEVEL Fader – select Learn MIDI CC.
Can I use Midi data on one track through multiple instruments | kfoody | Virtual Instruments | 1 | 07-14-2009 01:56 PM |
Multiple Instruments using midi keyboard | MiamiPsychic | MIDI | 2 | 06-09-2009 02:14 AM |
Multiple Midi Instruments | eklektos | MIDI | 1 | 11-03-2008 01:40 PM |
How do i use multiple instruments and reason/midi with 003?? | ostrange | Virtual Instruments | 1 | 01-18-2008 04:47 PM |
MIDI connections w/multiple instruments??? | Chazz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-21-2002 12:04 AM |
