Old 03-05-2014, 06:02 PM
2224 2224 is offline
Default re:16x16
Hi guys, I am using 2 16x16 interface with an ART tube pre amp and I have notice when trying to record vocals or an instrument the sound would cut out for like a second randomly, so I thought it was the pre amp went and got another one hook it up, the same problem, so I changed the cables, same problem,now all this was working before with no issue and it only happens when I am sending sound from the pre amp, I need to use the pre amp tomorrow for a session.
Can anyone point me in the right direction please?
JAMAICAN I IS
2008 2009 and 2010 Mac Pro 8 core with
64 GIG memory with 9 terabyte of hard drive space
blue ray player
HDX 1, 2 16X16 interfaces
sync I/O.
Old 03-05-2014, 08:58 PM
Default Re: 16x16
Originally Posted by 68Tele View Post
* Have you tried all the inputs on both 16x16's? May possibly be a bad channel?
* You might try testing with each 16x16 one at a time?
* Do you have any additional outboard gear inserted anywhere?
I did all the test I could think of 68tele and I have no other out board gear in line and no matter what interface I plug into I get the same result, same cable in both and same result, change cables same result,I am using 10.3.8
JAMAICAN I IS
blue ray player
sync I/O.
Old 03-06-2014, 04:55 AM
Default Re: 16x16
Did you try using only a single 16x16? And try it on both ports of the card?
Old 03-06-2014, 07:45 AM
Default Re: 16x16
No I did not but I will try this later today,
Is there a way to reset the interfaces?
Thanks
JAMAICAN I IS
blue ray player
sync I/O.
Old 03-06-2014, 01:55 PM
Default Re: 16x16
So I disconnected one of the interface and it now seems to be working, now could someone tell me what that was about please?
JAMAICAN I IS
blue ray player
sync I/O.
Can you use an HDX 16x16 and a 192 I/O together Neale Eckstein Pro Tools HDX & HD Native Systems (Mac) 14 02-15-2018 05:58 PM
Re:16x16 interface 2224 Pro Tools HDX & HD Native Systems (Mac) 2 02-02-2014 05:36 PM
hdx and 16x16 output red stanonbass Pro Tools HDX & HD Native Systems (Mac) 8 01-19-2013 08:10 AM
HD I/O 16x16 Fooks Pro Tools HDX & HD Native Systems (Mac) 3 04-03-2012 10:04 AM
Avid IO 16x16 versus Apogee symphonie 16x16 kristalan Pro Tools HDX & HD Native Systems (Mac) 0 06-28-2011 09:35 AM
