Old 02-23-2014, 03:39 PM
spiketronic spiketronic is offline
Default will not save score as PDF
with score editor open, I go to file, print score, hit the PDF button and tell PT11 to save the score to my desktop as a PDF file. No matter what I call the file and no matter where I try and save it to, it does not create a file I can find anywhere. The dialog box closes as tho the save was successful. My 10.8.5 Macbook will use preview to open other PDFs. Is there a setting I'm missing?
Old 06-17-2014, 09:33 AM
jrick79 jrick79 is offline
Default Re: will not save score as PDF
Were you able to find a solution? I'm experiencing the same issue.
Old 06-25-2014, 12:53 PM
tomorrowstops tomorrowstops is offline
Yup, same problem here.....anybody have an answer yet?
Old 09-12-2014, 11:45 AM
Curtisguitar Curtisguitar is offline
I ran into this last night and cannot find any solution. Any ideas, seems like a bug
Old 09-15-2014, 03:22 PM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
What is your OS and which Pro Tools Version?
What steps are you using that cause this problem?
I just tried the following:
1. Open the score editor
2. Right click on the score
3. Select "Print Score" from the bottom of the menu
4. Select "PDF" from the bottom left corner of the print dialog
5. Navigate to the area to save.
And the score was saved properly as a pdf. I'm on OSX 10.8.4, with PT 11.2
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 02-02-2015, 02:25 PM
twix twix is offline
Please tell me there is a work-around or fix for this?
Protools 11.3
OSX 10.10.2
Old 01-06-2017, 09:08 PM
krwin krwin is offline
To correct this, if you do not have a real printer, simply add a fake one:
1. Go to the Apple menu -> System Preferences -> Print & Scan
2. Click the padlock to unlock if necessary
3. Click the + sign above the padlock
4. Click IP
5. Enter a meaningless Address (such as 127.0.0.1)
6. Choose "Generic PostScript Printer" in the Use drop-down list
7. Click Add, then Continue
8. An error will appear. Click continue, then OK
Now try and save the score to PDF once again. It should work.
Old 09-17-2020, 05:00 AM
Cawbaby Cawbaby is offline
3 yrs later.
thx krwin
Dr. Caw Recording
www.drcaw.com
(-50) ERROR on Save / Auto Save oldrake macOS 1 10-14-2013 03:30 PM
Score Editor dreadkid08 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-21-2009 10:43 AM
Score Editor harryk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-24-2008 03:30 PM
PT 8 Score ed. Lyrics?? JGuth Pro Tools TDM Systems (Mac) 1 12-05-2008 02:24 PM
Can you score movies with LE? Miike Lee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-09-2003 05:48 PM
