Old 03-27-2013, 08:09 AM
BigBangPost BigBangPost is offline
Default Track show/hide markers disable track record status
Using sends and returns via aux tracks I've setup a number to audio layback tracks to print my deliverables. I've also setup markers to quickly recall track show/hide states of say just dialogue tracks, so it nicely maps over my controller via HUI.
If I recall my layback channels and record enable and solo safe them then switch to another marker and back again the record enable and solo safe states have turned off....
Many Thanks
Ben
Old 03-27-2013, 08:39 AM
Henchman Henchman is offline
Default Re: Track show/hide markers disable track record status
Most likely the state of the channel is included in the marker.
www.markhensley.tv
IMDB Credit List
Living the dream.
Old 03-27-2013, 08:54 AM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
I'll double check with the solo safe, but any channel that is record enabled has to stay visible if you want it to stay record enabled.
EDIT: Not having the same results regarding the solo safe, but the track un-record enabling itself was probably intentionally written as a safety precaution; most likely when disk space was much more of an issue.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 03-27-2013, 02:47 PM
Brandonx1 Brandonx1 is offline
If you hades track, it will go out of record. Doesn't matter how you hide it.
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 03-27-2013, 08:03 PM
elicious elicious is offline
if you hide/ show a track,
it will go out of rec enable,
not rec, as you can't show/ hide during rec.
i only wish you wouldn't lose solo status when changing views...
e
ihatetyping
HTML code is On
Track Show/Hide Disables Re-record Tracks reichman Post - Surround - Video 3 11-06-2009 10:20 PM
PT 8 and Track Show/Hide Window therecordinghouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 09-08-2009 08:04 PM
track show and hide with link track and edit selection ???? x9blade Pro Tools TDM Systems (Win) 4 10-11-2008 10:08 PM
Lasso in Track Show Hide ViniC Pro Tools TDM Systems (Mac) 1 12-05-2004 08:56 PM
Track show/hide question Drive d Pro Tools TDM Systems (Mac) 8 10-05-2004 09:23 PM
