Old 05-11-2012, 06:24 AM
hornedrum hornedrum is offline
Default f12 words, but command space doesn't?
This is really frustrating me as I have used the 'Command + Spacebar' to record since the beginning of time.
f12 works, but I just wish command+space would instead.
Any ideas?
Mac pro, PT 10.0.1, Lion 10.7.3
I haven't changed anything (that I know of) and this has just stopped working overnight. I might have deleted prefs to fix another bug, but pretty sure Command+Space is a deafault setting in PT, no?
Pre-post is not on...
Cheers.
Old 05-11-2012, 07:04 AM
ChuckS ChuckS is offline
Default Re: f12 words, but command space doesn't?
It's assigned by the OS in keyboard preferences to Spotlight - have you unchecked that assignment? Works here in PT 10.1.3.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 05-11-2012, 07:23 AM
Yeah, thanks, I've changed tht to a different shortcut too, still not working!
Old 05-13-2012, 05:34 PM
Hugh-H Hugh-H is offline
Hello,
I don't know when this crept in but an associate showed me this trick. Apparently even though you've unselected it in the Keyboard Shortcuts it's still stolen by the OS. Once you activate a second keyboard language and de-select it, the stealing is gone. Here's how we got around it, follow along if you can -
System Preferences / Keyboard
Click on Keyboard tab
Click on Input Sources near bottom
Click on some other language, I picked Afghan Dari because it's at the top. This will turn on the Menu Bar selector.
Click the Back button at the top of the window.
Click on Keyboard Shortcuts tab.
Click on Spotlight.
You'll see Cmd/Space still taken, uncheck it.
Click on Keyboard tab.
Click on Input Sources.
Unselect Afghan Dari or whatever you picked, the menu bar selector will de-select as well.
Close System Preferences.
Should work now. Credit to Tim H.
Hugh
Old 05-14-2012, 06:29 AM
Hughm, thanks so much, IT WORKED!!!
What a random workarouhnd, but I am a happy chap again, appreciados muchas :)
Andrew
Old 05-20-2012, 08:42 AM
theblotted theblotted is offline
thanks for the credit Hugh, you typed it out better than i explained it! =]
Old 03-12-2013, 08:36 PM
gtomassetti's Avatar
gtomassetti gtomassetti is offline
Kudos to Hugh's associate and to Hugh for posting it.
For the record, this fix works in Snow Leopard, with the following difference:
In 10.6.x it's System Preferences > Language & Text > Input Sources.
Other than that, the procedure is the same.
Strangely, I had to do this on both my MBP and my Mac Pro. F12 worked normally, and on the number pad on the Mac, 3 works as long as I have the keypad set for Transport rather than Classic.
Mac Pro 6,1 ("Garbage can"), late 2013, 3 GHz 8-Core Intel Xeon E5; 64GB RAM; MH ULN-2 (Ethernet MHLink connection)
PT Ultimate 20.12.0; REAPER64; PreSonus Studio One 5 Pro, Central Station Plus, and FaderPort
McDSP All Access; Slate Digital All Access; Waves Diamond 12.0; NI Komplete; EW GhostWriter
Finale 26.3.1
Old 01-11-2015, 09:28 PM
Josh Voyles's Avatar
Josh Voyles Josh Voyles is offline
I was also having this problem with Pro Tools 11 installed on my Mac.
The solution was to simply uncheck the command + spacebar preference in the keyboard menu and then restart. The restart part took me the longest to figure out.
Command-space bar not working zoff Pro Tools M-Powered (Mac) 19 09-05-2020 07:43 AM
where is the command+space gone ? groovebrother Pro Tools TDM Systems (Mac) 14 11-27-2012 02:16 PM
Option Command Space Bar (Not Recording in sync) adamjay Post - Surround - Video 1 08-17-2010 03:43 PM
Command + Space shortcut in Snow Leopard oha 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-17-2009 08:49 AM
can't record with command-space cebolao Pro Tools TDM Systems (Mac) 4 11-14-2001 01:23 AM
