#101
Re: Considering switching from HD3 PCIe to HD Native
UAD Apollo x16, UAD Apollo Twin Duo, UAD Octo Thunderbolt, Mac Mini i7 2018, Reaper DAW, Presonus Faderport, Arturia Beastep for DAW control, Former Pro Tools HD user (from V7 until V12.6). |
#102
Usually 7 out of 8 at 99% cpu limit but I've also tested 6 and 5 processors. I guess I should probably check going lower. With spotlight and time machine disabled and no other apps running, you'd think the OS wouldn't need that many processors. This has also all been with 10.7.2.
#103
#104
That's interesting. I haven't had a problem with UAD plugins once, with both the Harpertown and my previous ppc G5 ... Avid had me test the system with the UAD Quad card removed from the mac, and that didn't make a difference with the 909x errors. I'll definitely have to test all of the processor options, including going all the way down to one core.
#105
So is the consensus that the 3.33 Ghz 6 core westmere is better than the 2.4 Ghz 8 core for HDN? For an editing system, is there really that big a performance/stability difference? No real mixing or recording will be done on this system.
TIA for any feedback. |
#106
Were you having this problem in PT9HD also?
www.joelfountain.com |
#107
The 6-core seems to be best at low buffer (32,64) recording/mixing and makes Native feel most like a TDM system. |
#108
I was asking for experiences with 6 core versus 8 core not a judgment on what system I should be using. |
#109
You have to admit, without your added info, worrying about the difference between an 8 core and 6 core seems trivial. And very may well be even with it. |
#110
No one needed my added info to comment on experiences between 6 core & 8 core. There are too many attempts at one-upping around here instead of just answering the damn question. Stability is what I care about and why I was asking about 6 core vs. 8 based on this & other threads. I'd still like some feedback about that. It matters as this is for a client and they actually might care about the $$ difference since the 6 core is not a stock config, i.e. no discounts. |
Using PT9 with HD Native PCIE | KSR | macOS | 1 | 12-19-2013 12:28 PM |
HD Native... Thunderbolt or PCIe? | kirkbross | Pro Tools HDX & HD Native Systems (Mac) | 2 | 09-18-2013 10:25 AM |
PT10 DSP/Native switching | elicious | Pro Tools 10 | 0 | 06-12-2013 04:10 AM |
Switching from HD Native to Lynx AES16e ? | jacko | macOS | 0 | 01-10-2013 02:22 PM |
PT HD Native or PT9 with PCIE card | jcolagross | Pro Tools HDX & HD Native Systems (Win) | 1 | 04-28-2011 08:45 PM |
