Old 03-07-2011, 02:56 PM
1rons 1rons is offline
Default HD|Native I/O Suggestions?
I like the idea of the Omni interface, but I need more mic pres. Any suggestions about what to buy to get (at least) 8 mic pres, monitoring control, etc. in/out of the Native PCI card?
Old 03-07-2011, 06:48 PM
nst7 nst7 is offline
Default Re: HD|Native I/O Suggestions?
If you want to use the HD Native card with non Avid interfaces, your choices will be very limited, and those choices will mainly be converters only. A few that come to mind are Apogee Symphony IO, AD16x, and Rosetta series, or the Lynx Aurora, or the Mytek 8 x 192. Basically these are some of the few converters that have adapters to hook up to any kind of HD card. You would then need to get your preamps separately.
You might do better to get the HD I/O, and then something like the Focusrite ISA 828 (for 8 preamps) and the Dangerous Dbox for monitoring.
Keep in mind that you could also add some stuff to the Omni. You have the 2 built in preamps, and you could get 2 more for the other 2 analog ins. Then you could get a 4 channel preamp with a/d conversion to go into the adat in. A couple of examples would be the Focusrite 428 with a/d card option, or the Universal Audio 4-710d (with built in a/d conversion).
It might be cheaper to do that, and use the monitoring control of the Omni, then to do the first suggestion with the HD IO and buying everything separately.
Old 03-08-2011, 10:26 AM
ronstephens ronstephens is offline
Thanks. That's just the kind of info I need.
With my 002r I can connect 8 mic pres via analog, and 8 more via ADAT LightPipe (plus 2 more via SPDF). I don't know if the step up in quality re. HD|Native is worth the step backwards to 12 input max with an 8x8x8. If Digi (excuse me - Avid)had just put 8 analog ins, instead of 4, on the OMNI, I'd be all set.
Ron Stephens
[email protected]
Latest Pro Tools Studio, macOS 14beta, Mac Studio M1.
Does HD native or native native disable plugins when monitoring inputs? BasketCase Pro Tools HDX & HD Native Systems (Mac) 7 05-20-2013 08:48 AM
FLUX Elixier V3 AAX Native & DSP + Freeware Bittersweet V3 AAX Native & DSP released psmworld AAX Plug-ins 18 01-31-2013 04:16 PM
Tracking with AAX-DSP or with Native (RTAS or AAX-Native) Plug-ins Oblivion777 Pro Tools HDX & HD Native Systems (Mac) 10 05-18-2012 03:54 PM
SSL4000 native/ Renmaxx native/ DUY everpack native!!! cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-22-2007 07:58 AM
