Sound Distortion Issues with Pro Tools 8
Hello,
Been having some troubles with my newly installed Pro Tools rig. Things are ok in general except for an extremely distorted sound quality. It sounds like the system is running at a lower sample rate or bit rate and cutting huge chunks of sound out. Muting tracks leaves a strange, rattling, distorted noise when nothing is playing. I have a hunch that it's something to do with my laptop setup. Is that a viable option? Other suggestions? My rig: Pro Tools 8 MBox Mini Snow Leopard 10.6 OSX 2 GB of RAM on my system (my hunch for what's wrong, might it also be my sound card?) 30 GB of Hard Drive Space (running most of the audio off a USB linked external) Anything else I can specify that might help? |
Re: Sound Distortion Issues with Pro Tools 8
You should not be using a USB drive. Connect the external drive via firewire.
It would help to be a bit more specific with your setup/gear. You mentioned laptop, what kind of laptop and what are the specs? You say PT8, what version is it? PT8.? 8.0.0? 8.0.2? 8.1? Same with OS 10.6. Is it 10.6? 10.6.2? 10.6.6? Same with MBox Mini. MBox 2 Mini, or MBox 3 Mini? The RAM could be an issue if you are running an intensive session, i.e. lots of VIs, tracks, etc. |
Laptop is a 2007 Macbook Pro
- 2.2 Ghz Intel Core Duo - 2 GB 667 Mhz DDR2 SDRAM OSX is the original install of Snow Leopard, so 10.6 My copy of Pro Tools is listed as 8.0.4 in the manual I got with the install, but the outside packaging only says 8.0. So I'm not sure, but I think I'm running 8.0.4. Mbox 3 Mini This particular project is running about 30 tracks. Think that would be enough to make an impact on the RAM? |
Pro Tools version is shown in the startup box, or you can right click on the Pro Tools icon you use to launch the app and select 'Get Info'; it will show which version there. I don't have an MBox 3 so some other users may know a more specific cause of your problem, but you should still change your external hard drive connection from USB to firewire. That will improve system performance. |
Ok...updates. After sitting down with my professor and trying a few different things, it seems that the problem is coming from my computer itself. I've uninstalled and reinstalled Pro Tools and the MBox drivers several times over now, with no luck.
Sound is still distorted, even when running just one track of audio. I've also reset parameter RAM and reconfigured my settings several times over (with the help of Avid's support line). Does anyone think uninstalling and reinstalling Snow Leopard would do anything? Any other suggestions? |
Noise and distortion from a otherwise working PT application, I would be looking for hardware failure. Do you have Digi Core Audio manager installed? If so you can select the mbox as output for all mac audio in system preferences. Do you get the same distortion from f.ex iTunes? (You have to quit PT.) Is the Noise and distortion present in headphones also?
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
core audio's installed noise is present in headphones and yes, I do get the same distortion issues in my itunes and other audio. Have tried other interfaces and gotten the same issues. Someone speculated that it might in fact be my laptop USB port that's malfunctioning. Yikes. Think that's valid? |
Well, that rules out interface malfunction.
Could be. Have you tried a different cable?
I did a search for "usb cable" and immediately found other people who solved problems with bad sound by switching cables:
http://duc.avid.com/showthread.php?t...ight=usb+cable
I'll keep posting with hope that possibly there are some other ideas floating around out there. Been searching the site for suggestions to no avail. |
Pro Tools 11 issues... (midi + distortion) | jfed | macOS | 4 | 10-28-2013 02:29 PM |
Sound Distortion/Buzzing In Pro Tools SE? | StereoProphet | Pro Tools SE and Essential (Win) | 1 | 06-16-2013 02:27 PM |
sound card issues with pro tools 8 / windows 7 | jborkin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-19-2010 01:00 PM |
Pro Tools/ Sound Blaster compatibility issues? | narkopuppy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-05-2008 02:19 PM |
Sound distortion with Pro tools LE 7.1 | melodic101 | Pro Tools TDM Systems (Mac) | 0 | 03-16-2007 10:38 AM |
