Latency Issue
When I used LE there was a setting at the bottom of the options drop down menu for recording that would turn off all the plugins and reduce the latency. Is this not available on M-Powered?
Re: Latency Issue
I don't believe so. I have M-Powered and don't have that option, but I have heard of it on LE systems.
Re: Latency Issue
There isn't such a thing...
There is Lower latency monitoring @ the bottom but that does not turn off all plung(as another poster calls it) nor does is reduce latency; it jus allows u to monitor not hearing it...
Re: Latency Issue
Oh crap. What do you do, go through your whole session and bypass every plugin? It doesn't make sense not to have that.
Re: Latency Issue
Well to be honest I'm not sure what u mean?
I myself haven't used LLM in maybe 4-5 yrs on my LE rig & I pretty much keep it on 64buffer... what exactly is goin on or what u wanting to happen? help us a bit.. Com'o Claude...Let's be real
Re: Latency Issue
I have mixed my session and want to add another guitar part. There is so much latency I can't record. I always used to hit that Lower Latency on the option menu and I'd have no problem.
Re: Latency Issue
OK well, no deal on M-powered or Mboxes as far as LLM... Racks only...
Re: Latency Issue
If you hold shift while opening the session it makes all plugs inactive.
Re: Latency Issue
Re: Latency Issue
Yeahppp; & to make them active, jus hold 3 the hot keys & click on 1...
Another annoying issue. A good issue, but still annoying. Plugin latency. | DJ Hellfire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 25 | 05-20-2010 05:26 AM |
Latency Issue | FoodForSongs | Pro Tools TDM Systems (Win) | 0 | 09-20-2009 05:39 AM |
Latency issue. | the_dr38 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-04-2006 02:36 PM |
Latency issue! Please help! | illsub1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-27-2002 02:42 AM |
Latency Issue on PC | poisa | Digidesign Hardware & Software | 12 | 05-29-2001 01:36 AM |
