IE 8 how uninstall or disable it in WINDOWS 7 help
IE 8 how uninstall or disable it in WINDOWS some who knows please
Jascha Koneffke flutist www.prodmusica.cl GA-X58A-UD3R[/ I7 950 RAM 24Gb corsair 1600 (3 sticks) 9-9-9-24 MAC MacBookPro i7 2,3 15" RAM 16gb PT 11.3 003 Rack MBox 3 Pro |
Re: IE 8 how uninstall or disable it in WINDOWS 7 help
"Add or remove programs" in Control Panel. Uninstall.
I'll see thanks
Just trying to improove,Am doing 130 minutes and more session long ,no problem.my system usage changes whith External HD sata by esata port PCI 0 % CPU RTAS 3% CPU ELASTIC 0% DISK 49% when i used the external sata HD by USB port was PCI 0 % CPU RTAS 3% CPU ELASTIC 0% DISK 10% do you explain that difference, esata port is supposed to be faster than USB your opinion will be helpfull thanks
The BIG problem for MOST users was that IE8 was keeping PT (and many other programs as well) from even launching. That's why un-install it.....it doesn't run fine for EVERYBODY.
Exactly, & as many threads as there are & have been of IE8 causing problems & too Digi saying that if will hose things up, why would u say it runs fine? & Don't say it runs fine for u because ur 1 out of all the rest... & if that is the case(as we know) say it works for u or better yet, I wouldn't even say that because then u have people wasting time tryna make it work...
Start --> Run --> %WINDIR%\ie8\spuninst\spuninst.exe We had to use this method at our workplace when Add/Remove didn't work. Cheers!
Digi002 LE 8.0 XP Pro SP3 Athlon 64 FX-53 K8V Deluxe 4GB Dual Channel WD 80GB System WD 300 production 2X300 RAID1 (for backup) NVIDIA GForce4 Dual Head UAD1 Plug-in card ----------------------------------------------- Any sufficiently advanced technology is indistinguishable from a rigged demo. ----------------------------------------------- |
OK but IE8 is where/when people get problems; iloks & Digi stuff have been running for most every1 who post saying PT won't launch or whatever else it causes & when IE8 gets installed, then PT crumbles; so how would u say its not IE8 thatz causing the prob?
Disable Midi Driver Windows XP | opmusic | MIDI | 0 | 02-15-2014 02:52 AM |
Disable (not uninstall) plugins? | passion4music | Pro Tools 9 | 5 | 09-17-2012 09:55 PM |
Cannot Uninstall LE on Windows 7 | dwspc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-15-2011 01:58 PM |
Windows XP: how to disable usb devices at startup | jbro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 02-28-2010 05:28 PM |
How to disable Windows SP2? | Nicc24 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-08-2005 08:48 PM |
