Need help with getting a DELL 1537 up and running!
Hey, I have a dell studio 1537 and have had problems with tons of dae errors, even when only playing back 2 tracks, and thats with the buffer maxed! I looked online and it says the 1535 is unsupported..scary...so I'm hoping there is something I can do to get mine to work better. Attached is the sandra report I hope someone has an idea of what to do? Thanks so much!
SiSoftware Sandra Computer Model : Dell Studio 1537 Workgroup : WORKGROUP Host Name : Studio User : Rob Processor Model : Intel(R) Core(TM)2 Duo CPU P8400 @ 2.26GHz Speed : 2.26GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Mobile, Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 3MB, ECC, Synchronous, ATC, 12-way, 64 byte line size, 2 threads sharing Computer Platform Compliance : Intel Centrino Mobile Technology Mainboard : Dell 0P132H BIOS : Dell A02 09/02/2008 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3GB SO-DIMM Chipset Model : Dell PM45 Mobile Controller Hub Front Side Bus Speed : 4x 266MHz (1GHz) Total Memory : 4GB SO-DIMM Memory Bus Speed : 2x 399MHz (798MHz) Memory Module(s) Memory Module : Nanya NT2GT64U8HC0BN-AD 2GB DDR2 SO-DIMM PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : Nanya NT2GT64U8HC0BN-AD 2GB DDR2 SO-DIMM PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Video System Video Adapter : ATI Mobility Radeon HD 3400 Series (SM4.1, 256MB DDR2, PCIe 2.00 x16) Storage Devices Hitachi HTS543232L9A300 (320GB, SATA300, 2.5", 5400rpm, NCQ, 7MB Cache) : 298GB (C:) (D:) ST3750630AS (750.2GB, USB/SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 699GB (F:) Optiarc DVD+/-RW AD-7640S (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 298MB (E:) Logical Storage Devices RECOVERY (D:) : 10GB (NTFS) @ Hitachi HTS543232L9A300 (320GB, SATA300, 2.5", 5400rpm, NCQ, 7MB Cache) Hard Disk (C:) : 288GB (NTFS) @ Hitachi HTS543232L9A300 (320GB, SATA300, 2.5", 5400rpm, NCQ, 7MB Cache) IPITP_63 (E:) : 298MB (CDFS) @ Optiarc DVD+/-RW AD-7640S (SATA150, DVD+-RW, CD-RW, 2MB Cache) New Volume (F:) : 699GB (NTFS) @ ST3750630AS (750.2GB, USB/SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Peripherals LPC Hub Controller 1 : Dell (ICH9M) LPC Interface Controller LPC Legacy Controller 1 : Winbond W83687THF Audio Device : Dell (ICH9) HD Audio Controller Audio Codec : Integrated Device Tech 7675h Audio Device : Dell RV620 Audio device [Radeon HD 34xx Series] Disk Controller : Dell (ICH9) Mobile SATA AHCI Controller USB Controller 1 : Dell (ICH9) USB Universal Host Controller USB Controller 2 : Dell (ICH9) USB Universal Host Controller USB Controller 3 : Dell (ICH9) USB Universal Host Controller USB Controller 4 : Dell (ICH9) USB2 Enhanced Host Controller USB Controller 5 : Dell (ICH9) USB Universal Host Controller USB Controller 6 : Dell (ICH9) USB Universal Host Controller USB Controller 7 : Dell (ICH9) USB Universal Host Controller USB Controller 8 : Dell (ICH9) USB2 Enhanced Host Controller FireWire/1394 Controller 1 : Dell R5C832 IEEE-1394 Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Network Services Network Adapter : Broadcom NetLink (TM) Gigabit Ethernet (Ethernet, 100Mbps) Wireless Adapter 1 : Dell Wireless 1510 Wireless-N WLAN Mini-Card Power Management Mains (AC) Line Status : On-Line Battery No 1 : 100% Operating System Windows System : Microsoft Windows Vista Home 6.00.6001 (Service Pack 1) Platform Compliance : x86 Windows Experience Index Current System : 4.0 |
Re: Need help with getting a DELL 1537 up and running!
Your secondary hard drive says USB/SATA. How do you have it connected? USB drives do NOT work for recording Pro Tools sessions. It would also help to know which interface you're using.
Problem two is that four-letter word, DELL. |
I am using the mbox 2 mini. Currently i have a USB drive connected but usually use an eSATA connected drive to record.
USB drives are "problematic" so that's problem number one. Go back to your e-sata.
Disable the networking adaptors while running PT- Both of them.
Which specific DAE errors....
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Ive disabled the network adapters and done all the other optimizations listed and it makes no difference, its mostly -9093 hardware buffer, where it tells you to increase the size, then later says to decrease the size -9129
Also the system drive you are using is slow and has a very small cache. If you are trying any virtual Instruments from that drive you will see problems.
And if you insist on recording to that USB drive, you're gonna have problems.
Hmm, yeah i see that it is only a 7mb cache. can you get new hard disks for laptops? however this isnt happening when im using virtual instruments, im just trying to play back 2 tracks at once. Using virtual istruments or reason rewired in is impossible because i cant reduce the buffer to improve the latency.
And yes I know USB drives are problematic, but trust me, this isnt due to a USB drive. And have any of you tried using USB drives and have actually had problems? Because I know a bunch of people that I work with who use usb drives on huge sessions and have had no problems at all. anyways Thanks for all of your help its very appreciated...so is that the only thing you can see, is that the C:\ is slow and too small of a cache? |
AND you can't record reliably to a USB drive. Just sayin.
"Hmmm....USB drives aren't supported, I'm SURE it can't be that, so I won't try something else, but it still doesn't work...." Straight from the Digi compatibility page: USB 2.0 Hard Drives USB hard drives are NOT recommended or supported for use as recording drives. Limited testing has shown that performance with USB drives is inferior to that of FireWire drives. Thing is, if you go against the recommendations, it MIGHT work for awhile, then it just stops working for no APPARENT reason; but the reason is, you're attempting to get reliable performance from a configuration that they've told you ISN'T reliable. |
Dual Boot 10.6 running 8HD & 10.7 running 10HD | STL Audio | macOS | 3 | 04-14-2012 05:38 AM |
Older Dell running pro tools? | evankertman | Pro Tools M-Powered (Win) | 1 | 01-29-2011 02:58 AM |
Running Pro Tools Le on a Dell Inspiron 640m possible? | DJ PhilO(NZ) | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-04-2007 02:45 AM |
Dell Workstation 670 "Running out of CPU power"!!! | belouder | Pro Tools TDM Systems (Win) | 9 | 02-24-2007 09:22 AM |
Dell Workstation 670 "running out of CPU power" ! | belouder | Tips & Tricks | 0 | 01-09-2007 08:06 PM |
