Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 12-09-2008, 05:00 PM
440Hz's Avatar
440Hz 440Hz is offline
Default Corrupted Files???????
I am experiencing some strange PTMP 7.4.2 behavior.
When playing a session back, on hitting PLAY the STOP and PLAY button light up for a second then the PLAY flashes three times (STOP stays lit) then the track commences.
The CLICK is totally out of time.
Audio tracks are audible before (about 2 beats) the transport line meets them on the EDIT Window.
MIDI tracks (drums) are hopelessly out of time.
It seems that the whole timing structure of the track is compromised.
I have done EVERYTHING in the TECH SUPPORT FOLDER and removed ALL of my plugins other than what comes with PTMP 7.4.2
I have upgraded Xpand! and Structure to the latest versions.
I have contacted XLN Audio to check it is not a Addictive Drums fault.
I have Clean Uninstalled and re installed PTMP with the 7.4.2cs2 update.
Other sessions are working ok, but this one particular file (NEEDED!!!!) will not play ball.
Perhaps the session is corrupted??? How do I go about taking the Audio and Midi files from this session, opening a new session and inserting the Audio and Midi?
I have not had a chance to render the Midi as Audio yet as the session won't play in time!!!!
Would love some help on this one.
Cheers in advance,
Nic
Old 12-10-2008, 11:56 AM
DigiTechSupt's Avatar
Default Re: Corrupted Files???????
If it's only happening with this session, use Import Session Data with a new session to import everything from the corrupted session to the new one. You can do a search in the Pro Tools Reference Guide (under the Help menu) for more info on using Import Session Data.
Avid Audio Tech Support
Support FAQ
Old 12-10-2008, 02:32 PM
440Hz's Avatar
Hey Digi,
Thanks very much!
Sometimes all we need is a gentle push in the right direction
Nic
Old 12-11-2008, 03:30 PM
440Hz's Avatar
Seems to not be just one file that is faulting now.
Everything that I open is out of sync.
Could there be a clock problem with the M Audio Fast Track Pro?
Corrupted wav files patchworkmusic Windows 6 06-05-2016 09:22 AM
Wav files Corrupted Elvis_16 Pro Tools SE and Essential (Win) 8 12-17-2012 01:01 PM
Corrupted files? DannyG Pro Tools TDM Systems (Mac) 2 11-21-2008 10:43 AM
Corrupted wav-files... GW 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-08-2002 07:13 AM
corrupted files Mike T Pro Tools TDM Systems (Mac) 1 05-15-2001 08:29 AM
