Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 12-04-2008, 05:04 PM
440Hz's Avatar
440Hz 440Hz is offline
Default Intermittent midi sync fault
Hi all,
First up I'd like to say what a fantastic resource this is and thank you in advance for any help anyone has to offer.
After reading the 'READ THIS BEFORE POSTING' thread, I will endeavor to provide as much info as possible.
SYSTEM
iMac 7,1 2 GHz Intel Core 2 Duo. OS X 10.5.4
4 GB 667 MHz DDR2 SDRAM
LaCie 300GB d2 Quadra external drive (firewire 400)
Pro Tools M-Powered 7.4.2
M Audio Fastrack Pro
M Audio Axium 61
POD X3
DATALINK DHUB-H7 USB 2 HUB
VERSION LIST
Fri 5 Dec 2008 10:19:54 EST
Plug-In Versions
__________________________________________
Addictive Drums.dpm
BF Essential Clip Remover.dpm
BF Essential Corr.dpm
BF Essential Meter.dpm
BF Essential Noise.dpm
BF Essential Tuner.dpm
Chorus.dpm
Click.dpm
D-Verb.dpm
DigiReWire.dpm
Dither.dpm
Dynamics III.dpm
EQ III.dpm
EZdrummer.dpm
Elastic Audio.dpm
FinalPlug 5.dpm
Flanger.dpm
Funk Logic Masterer.dpm
Invert-Duplicate.dpm
L2007 Mastering Limiter.dpm
Lexicon PSP42.dpm
Line 6 - GEARBOX, POD Farm
Massey CT4.dpm
Massey DeEsser Demo.dpm
Massey TD5 Demo.dpm
MasterVerb 5.dpm
Mod Delay II.dpm
Multi-Tap Delay.dpm
MultiDynamics 5.dpm
Normalize-Gain.dpm
PSP 608 MultiDelay.dpm
PSP 84.dpm
PSP EasyVerb.dpm
PSP MasterQ.dpm
PSP MixBass2.dpm
PSP MixGate2.dpm
PSP MixPressor2.dpm
PSP MixSaturator2.dpm
PSP MixTreble2.dpm
PSP Neon.dpm
PSP Nitro.dpm
PSP VintageWarmer.dpm
PSP VintageWarmer2.dpm
Panorama 5.dpm
Ping-Pong Delay.dpm
Reverse-DC Removal.dpm
Signal Generator.dpm
SignalTools.dpm
Structure.dpm
TRackS1.x.dpm
TRackS1.xClipper.dpm
TRackS1.xCompressor.dpm
TRackS1.xEqualizer.dpm
TRackS1.xLimiter.dpm
Tape-Head.dpm
Time Comp-Exp-Pitch Shift.dpm
Time Shift.dpm
TimeAdjuster.dpm
TrackPlug 5.dpm
Trim.dpm
Xpand!.dpm
bombfactory BF76.dpm
test.bin
vt3.dpm
Plug-Ins Unused Versions
Cosmonaut Voice.dpm
Dynamics II.dpm
EQ II.dpm
Fairchild 660.dpm
Fairchild 670.dpm
Hybrid
Hybrid.dpm
JOEMEEK Compressor.dpm
JOEMEEK Meequalizer.dpm
Plug-Ins (Unlicensed)
Pultec EQH-2.dpm
Pultec EQP-1A.dpm
Pultec MEQ-5.dpm
Purple Audio MC77.dpm
SansAmp PSA-1.dpm
Slightly Rude Compressor.dpm
Tel-Ray Delay.dpm
Toolkits
Voce Chorus-Vibrato.dpm
Voce Spin.dpm
bombfactory BF-2A.dpm
bombfactory BF-3A.dpm
moogerfooger AD.dpm
moogerfooger LP.dpm
moogerfooger Ph.dpm
moogerfooger RM.dpm
Toolkits and Digitranslator Versions
Music Production Toolkit is not installed
DV Toolkit 2 is not installed
Digitranslator 2
Digitranslator 1 is not installed
I am also using REASON with REWIRE
The Problem
I have been using this current system for a couple of months now. The system is ONLY used for recording with Pro Tools. In the early stage it seemed quite stable, but as I started asking more of the system, things went awry. I had followed the installation and system set up meticulously.
I am having extremely annoying intermittent MIDI sync faults. I will be working on a session, complete the session. Save the session. Close down Pro Tools and my computer. INTERMITTENTLY ( but generally for the whole day) on restarting the session the MIDI is out of sync. This is generally the drums (Addictive Drums, which I have the latest version of)
The first time this occurred I was getting DAE 7400 error. The suggested solution to this problem had no effect.
I then followed the General Troubleshooting guidelines (bar turning off Bluetooth as I use a wireless mouse). Downloaded the TECH Support Folder and followed the instructions.
This seemed to really make things messy, so I ended up uninstalling Pro Tools and Addictive Drums (not even sure if this plug in is the problem, but was the one suffering the most) and re installing both of them. I Repaired Disc Permissions after doing this and low and behold, it was working again......... for a few days.
I Started a new session which had more MIDI info. Addictive Drums and REASON Rewired. The session was all good. I saved it and closed Pro Tools and shut down my computer.
Before opening the session the next day I did put a new POD X3 into the system. I was getting some sample rate messages until I changed the preferences within the POD, but I HAD NOT OPENED the previous days session yet.
When I did, the drums were out of sync again..... [bleep][bleep][bleep][bleep]!!!!!!
When this occurs, the TRANSPORT behaves strangely. On pressing PLAY there is a one second pause and the STOP button lights up followed by the PLAY button flashing before the track commences playing. This ONLY happens when I get the sync faults.
This morning when I opened the track it played fine (little [bleep][bleep][bleep][bleep]!!!) but I am sure I'll get this fault again when I don't need it.
I hope I haven't blabbed on too much. It would be REALLY GREAT to have some help on this because I'm getting near my wits end.
Cheers
Nic
Old 12-05-2008, 08:34 AM
DigiTechSupt's Avatar
Default Re: Intermittent midi sync fault
First - have you done all the steps in the General Troubleshooting thread, including turning off wireless/airport/bluetooth, making sure Firewire networking is disabled in the Network control panel and trashing preferences?
Even more importantly, have you updated all your plug-ins to Leopard compatible versions? Having just one incompatible plug-in in your plug-ins folder can cause all kinds of problems.
Avid Audio Tech Support
Support FAQ
Old 12-07-2008, 05:32 PM
440Hz's Avatar
Thanks for the reply.
As suggested I have followed ALL the instructions on the Tech Support Utility.
Removed Plugins, Trashed Preferences, Repaired Disc Permissions, turned off Airport, Bluetooth (now using cabled mouse), Firewire.
Uninstalled Pro Tools, re installed Pro Tools 7.4, 7.4.2 update and 7.4.2cs2 update.
Opened a session, it plays for 10 secs then the whole program freezes forcing me to Restart the computer.
Here is my current version list.
Mon 8 Dec 2008 12:17:53 EST
Pro Tools Version
Plug-In Versions
Addictive Drums.dpm
Chorus.dpm
Click.dpm
D-Verb.dpm
DigiReWire.dpm
Dither.dpm
Dynamics III.dpm
EQ III.dpm
Elastic Audio.dpm
Flanger.dpm
Mod Delay II.dpm
Multi-Tap Delay.dpm
Normalize-Gain.dpm
Ping-Pong Delay.dpm
SignalTools.dpm
Structure.dpm
Time Shift.dpm
TimeAdjuster.dpm
Trim.dpm
Xpand!.dpm
Dynamics II.dpm
EQ II.dpm
Toolkits
Digitranslator 2 is not installed
I have updated Xpand! Structure and Addictive Drums. Where do I find updates for the other Digidesigns bundled plugins?
Cheers
Nic
Old 12-10-2008, 02:58 PM
Unfortunately the current Tech Support Plug-in version generator does not work on Leopard. If you can provide me an email address, or let me know if the one in your profile is OK to use, I can email you the latest beta of the newer version.
On the main Digi site, click on Products, then choose Plug-Ins from the drop-down list.
Actually - hold the presses. I see the problem:
You should not install ANY other version of Pro Tools prior to 7.4.2. Doing so will cause problems. Do a clean uninstall of both 7.4.2 and 7.4, then restart and reinstall ONLY 7.4.2.
You can uninstall Pro Tools a couple different ways:
1. Run the installer for the version of Pro Tools you're trying to uninstall - when you get to the Custom Install page, click on Custom Install and select 'Uninstall'. When you continue with the uninstall, it will give you the option for 'Clean' or 'Safe' - choose 'clean'.
2. In your Pro Tools Utilities folder you may have a Pro Tools Uninstaller - double click and follow on-screen instructions. Again, you'll be given the choice of clean or safe uninstalls.
3. On most Pro Tools install CD's or DVD's there will be an Uninstall utility - same steps as in #2.
Support FAQ
Old 12-10-2008, 03:57 PM
440Hz's Avatar
Hey Digi,
Great!! Thanks for the heads up;-)
Have done the clean uninstall of both 7.4 and 7.4.2 and reinstalled 7.4.2
Should I bother doing the 7.4.2cs2 update?
All seems to be working fine at the moment.
I am doing further system upgrades at the moment.
Could you please suggest the best external drive (1 TB) to use with a late 07 Aluminium iMac 2Ghz Intel Core 2 Duo. I will also be upgrading to a 003 Rack in the not to distant future.
Cheers
Nic
Old 12-10-2008, 03:59 PM
440Hz's Avatar
Sorry,
forgot about the email.
The address attached to this account is fine to use.
Cheers
Nic
Old 12-10-2008, 04:11 PM
440Hz's Avatar
20 mins into todays session and it's faulting AGAIN!!!!!!!!
After doing the suggested clean uninstall of 7.4 and 7.4.2 and then reinstalling it worked for 20 mins then faulted.
I tested the reinstall with a session from last week. Worked fine.
Opened another session and it did the same fault. Press PLAY and STOP and PLAY both light up, PLAY flashes three times then the track starts. Audio is heard BEFORE the transport line meets anything in the edit window and ALL audio is jumbled and out of time.
This is becoming REALLY ANNOYING!!!!
Old 12-11-2008, 03:33 PM
440Hz's Avatar
Originally Posted by 440hz View Post
hi,
20 mins into todays session and it's faulting again!!!!!!!!
Opened another session and it did the same fault. Press play and stop and play both light up, play flashes three times then the track starts. Audio is heard before the transport line meets anything in the edit window and all audio is jumbled and out of time.
This is becoming really annoying!!!!
help>>>>>
Old 12-15-2008, 12:37 AM
440Hz's Avatar
Hey Digi...........
Whacha rekon????????
Old 12-15-2008, 02:14 PM
We just emailed you the version generator. Please post a list of installed plug-in versions.
Support FAQ
OMF Sync Issues -- Crossfades at fault? Max H. Post - Surround - Video 4 01-31-2011 06:10 AM
Sync HD having intermittent internal locking issues johnrambo Pro Tools TDM Systems (Mac) 3 01-07-2010 07:40 PM
Odd MIDI problem that I'm sure is my fault . . . The Zone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-18-2008 04:53 AM
Urgent QT sync problem - is it my fault? idris Post - Surround - Video 4 07-14-2008 07:58 AM
Bizarre Rec-Enable MIDI routing fault. accession MIDI 7 11-28-2007 01:33 AM
