Old 10-18-2008, 01:29 AM
andycopeman andycopeman is offline
Default unable to make my FW drive "audio record volume"
I recently upgraded to PT LE 7.4. I'm running a HP Compaq 6710b with 2ghz duo core, 2 G RAM etc and an MBox2 Pro.
When I try to open an old session (created with 7.1 or 6.9 or 6.4) I get this error: "Session must bo on an audio record volume. If permitted, set the volume(s) in question to "R" (record) in the Workspace"
My sessions are all on a external FW drive which ran OK before I upgraded. I have tried to change the permissions to "R" but that tells me that the drive is in the wrong format (FAT).
This never happened before.
I've googled this error and searched on DUC, and have found many references to this problem with macs, but not for PC's.
I've trashed the DAE prefs and the Digidesign databases on all drives but I still get the problem.
Do I really have to re-format my FW drive? If that is the case, then my opinion of Pro Tools, which I have been using and teaching for years, will go from very high to very low.
I don't have another drive with enough space on it to back-up my FW drive, so this process will be a complete pain in the proverbial.
Help!
cheers and thanks
Andy
Old 10-18-2008, 01:55 AM
SeedGuy SeedGuy is offline
Default Re: unable to make my FW drive "audio record volume"
7.4 is no longer compatible with FAT drives. You need to reformat to NTFS.
Old 10-18-2008, 08:11 AM
You should be able to copy/move your sessions to any other drive, then reformat the firewire drive and then copy/move the sessions back onto that drive. You might even consider getting a cheap USB drive to use for this transfer and backups.
AudioSuite results in "unable to create a new audio file on drive" gorgon Pro Tools M-Powered (Mac) 7 07-30-2017 03:35 PM
PT11 - Error "Session must be on an audio record volume" gondor1976 Pro Tools 11 11 12-02-2013 03:16 PM
Pro Tools error message "Session must be an audio record volume" DeejayMaurice 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 09-10-2011 06:42 AM
"unable to locate m-audio hardware. Make sure device is connected and powered on" bfreshmoney Pro Tools SE and Essential (Win) 3 09-01-2010 06:38 AM
Can't Save, I get "Audio Record Volume Message" elijahtrotsky General Discussion 1 03-10-2009 08:44 AM
