Old 08-24-2004, 07:49 PM
Cargoplex Cargoplex is offline
Default MBox Stereo Input Problem w/ Coreaudio App(s)
The configuration in question regards Audio Hijack Pro 1.3.1 & Digidesign Coreaudio Driver 6.5.2 running on a 1 GHz eMac running OS X (10.3.5).
I successfully use Audio Hijack Pro and its included LineIn app to record radio programs through my MBox. The ability to set a timer and have it record at the same time everyday is wonderful.
The only issue I've had is that I can't seem to record stereo into Audio Hijack Pro. No matter what settings I configure in either Coreaudio or Audio Hijack Pro, I'm only able to record mono via the MBox's Channel 1 input. This is not a problem for this specific use, but I would like to find a solution to this problem since it also occurs when attempting to record a stereo source into Bias Peak.
Does anyone have any advice for me? Thanks.
MBox / Pro Tools LE 6.4 / eMac G4 1GHz / OS X (10.3.5)
The world sounds better through headphones.
Old 08-26-2004, 05:19 PM
Default Re: MBox Stereo Input Problem w/ Coreaudio App(s)
Nobody's experienced anything like this? Are there any Peak users that are successfully recording stereo via the MBox? Thanks again.
Mbox 2 Stereo Input Problems? t_homas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-13-2010 07:25 PM
MBox problem - bad hiss on 1/4" input, but XLR input is ok!(?) haney411 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-31-2008 10:22 AM
Mbox mini - stereo input being sent to both R & L monitor Dr.Oates 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-25-2007 08:03 AM
mbox stereo input- panning issues mrtunes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-25-2005 09:55 PM
MBox, 4 channel input? (2 x stereo???) ACEtone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-22-2003 01:36 AM
