Old 05-05-2004, 04:53 PM
Cargoplex Cargoplex is offline
Default Final Cut Express & MBox?
Does anyone know how to make Final Cut Express play audio through the MBox via Digidesign's Coreaudio Driver? Thanks.
MBox / Pro Tools LE 6.4 / eMac G4 1GHz / OS X (10.3.5)
The world sounds better through headphones.
Old 05-05-2004, 05:34 PM
laieboy laieboy is offline
Default Re: Final Cut Express & MBox?
yes.
Old 05-06-2004, 04:35 PM
OK, can anyone other than this smartass help me out? Thanks.
Old 05-06-2004, 05:42 PM
Scott Sheppard Scott Sheppard is offline
Yes ...
If the CORE AUDIO is set up correctly then it will show up in the AUDIO/VIDEO set up menu.
Just select the MBox from the pull down menu under Audio Playback.
I hope this helps
Thanks
Scott Sheppard
Executive Producer
Host - Broadcast Radio
The Inside Mac Show
http://www.insidemacradio.com
Old 05-06-2004, 06:44 PM
I forgot to mention that I am using version 2.03 of FCX, and am unable to locate the Audio/Video setup Menu. Maybe you could steer me a little closer if it is version 2.x you're working in Scott? Thanks for your help!
Old 05-07-2004, 04:07 AM
Let me look into this and I will get back to you. I know its there on FCP HD. The only version of FCX I have is 1.?
Scott Sheppard
Executive Producer
The Inside Mac Show
Final Cut Express MBOX II Workaround..Help... tomhartman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-10-2009 10:24 AM
No sound for final cut express? digifriend 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-16-2009 05:24 PM
Anyone using Final Cut Express with 002? tomhartman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-20-2005 03:11 PM
Final Cut Express 2 jake_5150 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-25-2004 04:36 PM
Avid Express DV vs Final Cut Pro? letrev Post - Surround - Video 7 12-23-2001 02:21 AM
