Final Cut Express & MBox?
Does anyone know how to make Final Cut Express play audio through the MBox via Digidesign's Coreaudio Driver? Thanks.
MBox / Pro Tools LE 6.4 / eMac G4 1GHz / OS X (10.3.5) -------------------- The world sounds better through headphones. |
Re: Final Cut Express & MBox?
yes.
OK, can anyone other than this smartass help me out? Thanks.
If the CORE AUDIO is set up correctly then it will show up in the AUDIO/VIDEO set up menu. Just select the MBox from the pull down menu under Audio Playback. I hope this helps Thanks
Scott Sheppard Executive Producer Host - Broadcast Radio The Inside Mac Show http://www.insidemacradio.com |
I forgot to mention that I am using version 2.03 of FCX, and am unable to locate the Audio/Video setup Menu. Maybe you could steer me a little closer if it is version 2.x you're working in Scott? Thanks for your help!
Final Cut Express MBOX II Workaround..Help... | tomhartman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-10-2009 10:24 AM |
No sound for final cut express? | digifriend | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-16-2009 05:24 PM |
Anyone using Final Cut Express with 002? | tomhartman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-20-2005 03:11 PM |
Final Cut Express 2 | jake_5150 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-25-2004 04:36 PM |
Avid Express DV vs Final Cut Pro? | letrev | Post - Surround - Video | 7 | 12-23-2001 02:21 AM |
