Old 06-29-2017, 05:33 AM
DJ Hellfire DJ Hellfire is offline
Default Bug: When selecting a favorite plugin insert, the plugin above the one selected opens
Saw this bug pop up in 12.7.1 and is still present in 12.8.
I have a bunch of my go-to plugins favorited in the inserts menu (hold cmd and select a plugin to add them to favorites), and periodically a bug happens where I select a certain plugin (say Studer A800) and instead of the Studer popping up, Pro Tools opens the plugin above the one I selected (in this case would be SSL 4000 Buss Compressor). And this happens for any plugin I try to open. So in order to get the plugin I actually want, I have to select the one below it. Closing and reopening Pro Tools usually fixes the problem temporarily.
Anyone else seeing this?
EDIT: Here's my list of favorites attached so those with this issue can compare and maybe we can narrow it down to a possible specific plugin issue.
www.HellfireBeats.com
UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61
Pro Tools 2021.12
Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2
16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15
Old 06-29-2017, 05:56 AM
strangepumpkin strangepumpkin is offline
Default Re: Bug: When selecting a favorite plugin insert, the plugin above the one selected o
Yeah, I've seen that issue a couple of times. And, yes, restarting pro tools usually fixes it. I haven't been able to recreate it on demand though.
Kyle Whittaker
www.strangepumpkin.ca
Mac Pro (2013)
3.5GHz 6-Core Intel Xeon E5
32 GB Memory
OS X 10.12.6
PT 2018.1
Old 06-29-2017, 06:17 AM
john1192 john1192 is offline
are these by chance all UAD plugins ?? or a mix of manufacturers ??
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 06-29-2017, 06:20 AM
For me, it's not plugin dependent. I've seen it happen with Slate VTM and VMR specifically.
Kyle Whittaker
Mac Pro (2013)
32 GB Memory
OS X 10.12.6
PT 2018.1
Old 06-29-2017, 06:22 AM
cool, just trying to narrow it done if possible .. i am going to try and repro here right now .. lets see what happens ...
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 06-29-2017, 06:26 AM
well, i will keep an eye on it .. cannot make it happen right now .. all seems fine .. Q: do these Favorites go away when Trashing Pref's ???
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 06-29-2017, 06:57 AM
Any plugin that is in the favorites list. Selecting via manufacturer or type doesn't reproduce the issue.
Pro Tools 2021.12
Old 06-29-2017, 07:00 AM
copy that .. i have a few things in my favorites .. at this time i cannot repro but will keep watching in case it comes up
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 07-02-2017, 07:44 AM
Jperkins Jperkins is offline
I've been experiencing this and reporting it for awhile now and nobody has ever commented about it so I thought it was something on my end.
It would be great if a solution could be found.
For me, it doesn't seem to be tied to a specific plugin and doesn't happen all the time, but it happens often.
Sometimes it even loads a plugin more than one listing up so you have to keep guessing to get the desired plugin to actually load.
iMac Pro 3.0GHz 10-Core • 64GB RAM • SSD for OS and audio • MacOS 10.13.3
http://www.mysteryroommastering.com/
http://www.justincarlperkins.com/
Old 07-02-2017, 07:48 AM
Here's a download link to the GIF incase the forum doesn't support them:
https://www.dropbox.com/s/4d991uf0gu...s_BUG.gif?dl=0
Choosing which EQ/Dynamic plugin opens on Artist mix Interactivesound Artist Series 3 04-04-2017 01:31 PM
Instrument Plugin opens every time I touch fader [email protected] Artist Series 1 12-05-2016 09:32 AM
What's you favorite Plugin Filmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 45 03-28-2010 04:14 AM
What's your favorite compressor plugin? Allbaldo Pro Tools TDM Systems (Mac) 10 06-14-2005 01:35 PM
Favorite Delay plugin celdry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-26-2003 12:36 AM
