iTunes but not PT sessions out through S/PDIF / Coax out Digi003. HELP!
Hi - First time DUC user. I have a Digi003 rack using PT 8.05 on a MacPro. I am trying to run audio out through S/PDIF (RCA) from the 003 to my home entertainment center but have had only limited success; I can get iTunes to play through but not any ProTools sessions. Basically, any audio I run through DigiCore plays through the system EXCEPT for protools sessions. The problem: I can't start up PT with DigiCore running... PT makes me close it first. Then, ProTools will play but I don't get audio out through my home entertainment system. I've tried changing from 16 to 24bit sessions but haven't had any luck. Any suggestions??
many thanks |
Re: iTunes but not PT sessions out through S/PDIF / Coax out Digi003. HELP!
In Pro Tools' Hardware Setup, make sure the Optical Format is set to ADAT.
In the I/O Setup, delete all paths from the Inputs tab and then hit "Default". Do the same for the outputs. Now assign the I/O appropriately in your session and you'll get audio out the S/PDIF as long as that it where you assign it.
I'm pretty sure home entertainment systems receive TOS over optical where as Pro Tools uses ADAT.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
Possible to get Digi003 to work with iTunes? | toddamo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-20-2008 09:23 AM |
DIGI!! BUG!!! 96KHz and S/PDIF coax not working? | mahler007 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 08-12-2007 01:38 PM |
ext. clock via S/PDIF coax in, does it work w/out problems? | kmshroom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-04-2003 11:45 AM |
Please Help-using the 001 coax S/PDIF | pfd4 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-16-2003 11:38 AM |
Sony portable DAT -> coax S/PDIF on AMIII and/or 001? | Sugarite | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-03-2001 08:46 PM |
