Old 09-02-2006, 04:38 PM
antonmajor antonmajor is offline
Default audiosuite changes are not being applied to track
-powerbook g4 (non-intel)
-pro tools le 6.9.2
-mbox 1 (legacy)
-Mac tiger 10.4.7
-external lacie firewire drive in mac os extended journaled mode
Problemo:
Any audiosuite change i try to put in wether it be bluetubes, default reverse, bombfactory gain etc... nothing will take on the track.. the track does not change
it was working fine one day and now its not...
You can click undo and the program seems to think its modified the track, but visually and audibly, nothing changes whatsoever
please help,
anton
Old 09-02-2006, 05:20 PM
yOkO yOkO is offline
Default Re: audiosuite changes are not being applied to track
that's a FAQ
press "use in playlist" in the audiosuite plugin
your audio is processed but doesn't appear in the edit window
it's in the playlist
so what
Old 09-02-2006, 05:39 PM
gracias!!! i can't believe i missed that!!! damn!
Old 09-02-2006, 05:49 PM
gracias!!!
por nada bro
so what
Old 09-02-2006, 06:55 PM
southpaw13 southpaw13 is offline
Default Need Help... Track could not be record-enabled....
Hello,
Can anyone help me? I'm running an MBox with an IBook G4 1.33 Ghz/PT 6.9.2
I can get a session going, but as I try to enable a track to record. it gives me an error stating.......
Track could not be record-enabled because it doesn't have both an active input and output assigned. If anyone can be of help that would be great!
Thanks
Old 09-03-2006, 01:52 AM
kurt's Avatar
kurt kurt is offline
Default Re: Need Help... Track could not be record-enabled....
Hello,
Track could not be record-enabled because it doesn't have both an active input and output assigned. Thanks
Read the statement again.. You have to assign what input you are recording & where (Master?) it is going too.
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5
PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear.
http://www.mmvstudios.com
Any way to figure out effects settings applied to a track? Lqoau 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-03-2013 05:06 PM
AudioSuite Plug-ins with a MIDI track? jimmyl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-23-2007 04:57 PM
why is automation applied to other track controls? chuckles98 Pro Tools TDM Systems (Win) 0 12-24-2006 01:50 AM
More Than ONE Audiosuite plug per track?? ckjbod 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-02-2002 08:32 PM
best way to audiosuite a track of white noise love666 General Discussion 0 05-10-2001 12:58 AM
