Old 10-24-2018, 02:03 PM
clancychris clancychris is offline
Default Can't commit tracks due to track count
Just finished a rather large mix and I thought it'd be a great idea to commit every single channel to audio for archiving and stem creation but when I highlight the tracks it tells me I can't commit them as it would exceed the track limit.
Totally understand that would be an issue but surely selecting the "delete" the tracks after committing should override this?
I'm now a bit stuck and unable to do commit things, is there any way around this?
All I can think of is bouncing out everything as stereo tracks (to maintain panning and sends) but then I won't be able to put them back into a session as the mono tracks will become stereo and again exceed the limit of tracks
Old 10-24-2018, 02:55 PM
Carl Lie Carl Lie is offline
Default Re: Can't commit tracks due to track count
Have you tried making some inactive? Not sure if that will work but just wondering.
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 10-25-2018, 12:50 AM
Gave that a go but I think it's the overall track count that gets me. I'm having to do it 8 tracks at a time or so and then I occasionally run into a bug where it tells me I've run out of tracks, so I re-open the session and it's fine again.
Old 10-25-2018, 11:28 AM
daeron80 daeron80 is offline
Workaround would be save to a new version of the session (add "rev1" or whatever to the end of the filename), then commit as many as it will let you with "delete" selected. Then do that many more. Repeat until done.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 10-25-2018, 02:42 PM
Big Mother Big Mother is offline
I was thinking along the same lines as daeron80.
My thought was to create a new session and import session data in batches, commit, delete, import next batch, etc
PT 2023.12 / Mac Mini M1 16gb SSD / OS X 14.2 / UA Apollo
Old 10-27-2018, 12:56 AM
I'm managing to get through everything by committing 8 tracks at a time but what's killing me is there seems to be a bug whereby I commit say 16 tracks and then it tells me I can't do the next batch of 8 as it's run out of tracks.
I restart the session and it works fine.
It seems Pro Tools commits the track, deletes the original but doesn't clear the allocation for it. So I'm constantly opening and closing the session to get it done.
I haven't tested it but I think it would be the same issue starting a new session, importing and committing. I'd have to constantly open and close it.
It'd just save me so much work if I could highlight everything and press "commit" "delete" and then I can archive a session that's entirely futureproof
Old 10-29-2018, 08:00 AM
Argh. Bug report time.
David J. Finnamore
Old 10-29-2018, 08:12 AM
babaorum babaorum is offline
It's annoying in 2018 to see a professional DAW limitated in terms of number of tracks ...
Only the system should be a limit.
Pro Tools 2024.3 - Cubase pro 113 64bits- Windows 10 pro 64bits - wavelab 12 pro - core i9 9900K - 32 Go RAM All SSD- interface : ANTELOPE ORION Synergy Core.
Ideal-Sound Not_To_Flow
Old 10-29-2018, 01:46 PM
Got a case open about it now and sent a video of the issue to Avid support so hopefully it'll get a fix.
Ideally they'll change the way it works so you can commit an entire session of 128 mono tracks as long as you select delete. I don't have a real use for Pro Tools HD as I do mainly mixing and it works just fine with my setup. Parting with £1500ish for an upgrade to commit tracks is a bit of an ask
Old 10-29-2018, 02:32 PM
midnightrambler midnightrambler is offline
Seems like you're making very hard work of it to me.
Cant you just save a session with the first 64 tracks, another session with the second 64 tracks, then commit in 2 batches? Then import the 2nd committed session tracks into the first session?
I know you've encountered a bug, and yes it needs fixing, but working around bugs is probably what we spend half our lives doing.
PT 12.4 Max audio track count limited to 22 Tracks??? toolgirl Pro Tools 12 1 02-29-2016 09:39 PM
HELP! PT 11 actual track count less than max but can't create tracks tooold macOS 6 03-28-2014 04:59 AM
How can I increase my audio track count beyond 192 tracks? Sukram Pro Tools TDM Systems (Mac) 21 06-20-2011 01:52 PM
Track count still 48 tracks on 88.2 KHz (PTS 9) andre67 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-06-2010 05:18 AM
002R Track count maxxes out at 28 tracks ThisBeatsWorking 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-10-2004 05:32 PM
