Old 11-14-2006, 08:15 AM
sixmoons sixmoons is offline
Default Pt will not support unmapped network volumes
Ok here is a new one for me. Everything has been working fine but today when i go to load a tune pt say's "pt will not support unmapped network volumes." What the heck does that mean?
Sony vio 2.6ghz
1 gig ram
Lacie hard drive D2
firewire 1814
Old 11-14-2006, 07:44 PM
Gunnell Gunnell is offline
Default Re: Pt will not support unmapped network volumes
Are you working from an external drive? I have gotten this error message before when I open pro tools up BEFORE turning on my external hard drive and trying to open files from the external drive. PT checks your set up out as it's starting up so if you try to tell it to use files that are on a drive it didn't see when it started up, it'll give you this message. That's what I've concluded at least. If this is the case for you, all you have to do is close PT and open it again (after your external drive is recognized by your system). Hope this helps.
OSX 10.8
Pro Tools 10 / 11
Sapphire Pro 40
Mac Pro 2.66 GHz Quad-Core Intel Xeon
10 GB 1066 MHz DDR3
Old 11-15-2006, 08:23 AM
Thanks for the feedback what you described is extactly what happened and the remedy worked.
Unmapped Network Volumes???? snookjohn Pro Tools TDM Systems (Win) 1 07-01-2010 08:14 PM
why do I get a "protools does not support unmapped network volumes? oterrero Pro Tools SE and Essential (Win) 1 03-18-2010 09:53 AM
Pro Tools does not support unmapped network volumes?...HELP! dm3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-21-2010 09:12 AM
Error - Unmapped Network Volumes lovett 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-25-2006 10:14 PM
ProTools does not support unmapped network volumes Matt Whritenour 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-20-2005 05:28 AM
