Avid @ NAMM 2018
Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 04-15-2017, 04:50 AM
Prollo123 Prollo123 is offline
Default Re: EuCon 3.4/3.5Mouse troubles
@BSTEEVE: Same here, 3.6 doesn't fix it... My mouse isn't strange at all, when i doesnt use it as external Workstation... But with that crappy Avid Driver Adobe PP wont work right together...
Had always Trouble with that stupid Avid Artist ****sport
>Thanks for nothing
@Topic... Mouse rans Retard (some Kind of laggy) when i set the pollingrate to >1000 Hz or too high of my mouse... but happen only when that stupid EuControl runs... (err that was before Win10 Creators Update! Now ist totally broken!)
Check how high your polling rate Setting of your mousesoftware is.
Old 04-15-2017, 10:10 AM
EddieJones's Avatar
>Thanks for nothing
Are you using 2 workstations ? If not make sure the External Workstation setting is not checked. We are still working on a fix so that you can have a 2nd Workstation with Windows Creators and that should be in the next release.
Old 04-15-2017, 10:32 AM
No i don't... but when unchecked my Artist Transport wont work with Adobe premiere!
Mhh in short test it worked unchecked... suddenly, earlier this day it won't (inproper function of e.g. jog/shuttle)
In past i need to check this Option because of fixing any problem. I forgotten why i had to check it. Sure is that something don't work properly...
Why the mouse (e.g. moving any window) went crappy when polling rate of mouse is set too high?
Or is this a Problem of this "external WS"?
Edit: And why i cant use 2 Wheel Softkey Command together with Premiere Pro? (Set 2x Wheeltype where one is shuttle and the other jog on one! softkey... with properly Edit Control Function: Shuttle or Jog. Shuttle won't work anymore...)
Old 04-15-2017, 12:08 PM
EddieJones's Avatar
Checking External WS restarts Eucon...that is what is probably fixing issues, not this feature.
To be able to capture the mouse and Keyboard and pass onto a second WS we had to have a driver that sits in between. This extra layer probably can't handle the high polling. Is there a reason why you need it so high? BUT anyway you don't need External WS so should leave that off.
If you have other issues we can try and find out what they are.
Old 04-22-2017, 03:47 AM
yoerik roevens yoerik roevens is offline
wow, for the past few months I've had fatal cpu spikes followed by AVE errors forcing a full windows reboot about every 2 hours. Turned down mouse polling from 500 to 125 Hz (didn't even know that setting existed since I'm not a gamer). Haven't had a single crash in 2 days since.
Old 04-22-2017, 04:01 AM
And noboby knows, that the second layer fails!
Old 04-25-2017, 03:08 PM
Running Artist MIX and Transport here with PT[Control on iPad(2nd gen) with Eucon 3.6 with no issues.(using Logitech G300s gaming mouse)
Asus x99, Intel i7 6800K, 32 gig DDR4, GeForce 750 Ti, HD/Native, HD IOx2, PT11HD, UAD Quad, preamps from Vintech, Five Fish Audio, Miktek, Focusrite, Chameleon Labs and Midas..............................
www.capricornsoundworks.com
Old 06-29-2017, 09:55 PM
v3.6.1... nothing changes...
Old 06-29-2017, 10:53 PM
EddieJones's Avatar
What exactly is the issue ?
EuCon suddenly broken - Eucon client can not access the bonjour service noiseboyuk Artist Series 0 04-12-2016 12:34 PM
Eucon 3.2.2 installer error + firmware downwards compatible with eucon 3.1 deauditievedienst Artist Series 0 08-05-2015 02:09 AM
EUCON 2_6_1 eucon discovery cant find ip klaukholm System 5 2 10-22-2011 12:01 PM
Alert - EuCon 2.5.6 is only for Pro Tools 9 and EuCon DigiTechSupt Artist Series 11 02-24-2011 11:25 PM
