PT 7.4 with new motherboard and processor
Hy.
I did an upgrade to my pc: CPU Intel Core 2 Quad Q8300 2,5 ghz and MB Asus P5Q-SE2. I didn't reinstaled Windows. I open PT, open a project but when I hit play it give me a message error "Dae error -7401 was encountered" What to do ? Thanks ! |
Re: PT 7.4 with new motherboard and processor
But if i am creating a new project and record in it it works fine.
That, in my opinion, was a mistake. In my experiences, it is necessary to install windows from scratch when upgrading hardware such as a motherboard and/or processor.
Also, remember this; backups are your friend, and saviour.
How do i back-up all my installed plugins?
If i'll do a system recovery it helps ? |
You don't. You would need to re-install them.
No. A system recovery would load everything for your OLD processor. A fresh install of the Operating System is usually required in this case. What I was referring to with backups is once you get it all installed and working again, make a backup.
How do i do the back up?
I recommend using a disk imaging software such as Acronis True Image (that's what I use and prefer on Windows). Others prefer Norton Ghost.
There is also the freeware Clonezilla, but you have to reboot from the disk to make it work. This is all for after you have re-installed and solve your problems. It will not help you solve the problems you are currently having. Have you tried updating the PACE drivers like I recommended?
I instaled pace drivers. And this happend http://www.zshare.net/image/64359727e8e95e1a/
I dont't know why my system is crashing. I changed to power supply (Sirtec 500W) too but didn't solved my problem.
Before i didn't had such a problem. This is just since i changed the motherboard and the CPU. What should i do ? |
Help!!!! Motherboard and Processor | Obscene | Pro Tools M-Powered (Win) | 2 | 03-07-2006 10:46 AM |
Help!!!! Motherboard and Processor | Obscene | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-07-2006 10:37 AM |
new motherboard and processor | abel quintanilla | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-22-2005 07:45 AM |
motherboard processor speed | polkbrosmusic | Pro Tools TDM Systems (Win) | 0 | 09-04-2002 02:58 AM |
motherboard processor help | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-25-2001 05:59 PM |
