Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 01-09-2018, 04:39 AM
crizdee's Avatar
crizdee crizdee is offline
Default How old is your DAW computer?
My Harpertown 8-core intel xeon 2.8 GHZ Mac pro 3.1
10 years old this month
On most days for 10 plus hours
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-09-2018, 04:55 AM
Raoul23 Raoul23 is offline
Default Re: How old is your DAW computer?
My Harpertown must probably be that old too but I’ve only had it 3-4 months lol and love it. Not once missed a beat
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 01-09-2018, 05:51 AM
Drew Mazurek's Avatar
2012 Six Core cheese grater here. With 2 UAD cards, still plenty of juice.
www.drewmazurek.com
Old 01-09-2018, 06:43 AM
EGS's Avatar
EGS EGS is offline
My 2010 self-build is (still) a decent & stable workhorse.
Which raises a question:
What typically dies first? Power supply? CPU? Ram? Motherboard? I'm thinking perhaps CPU due to general heat & abuse. Do you suggest replacing components as a hedge against failure?
Click for audio/video demo
Click for resume
Old 01-09-2018, 07:54 AM
Ben Jenssen's Avatar
2008 Mac Pro 3,1 Harpertown 4-core 2,8kHz.
3 HDD
1 SSD:
Partition1: OS X 10.6.8, PT 10.3.10. for DAW work.
Partition2: Mac OS Sierra 10.12.5 for everything else.
Running smooth as ever.
The SSD upgrade gave it new life.
(The regular Sierra installer won't install on this mac, but I found a hack on the web.)
Old 01-09-2018, 08:00 AM
That's my current machine that I got a few months back from OWC. From what I could find out the machine's past owner was Sun Microsystems so you know it got a workout. No UAD cards (yet). Runs as cool as cucumber.
My iMac system lasted just about 5 years when it fried it's video card. Also fried the replacement card so I'm thinking something else went bad inside. Not putting any more money into it at this time. I did like having the two machines working together in a client/master environment with VEPro and the cheesegrater.
Jack
QAPLA!
Old 01-09-2018, 09:33 AM
My old machine ran for a good 3 years but the motherboard failed. I threw in a similar mobo and went back to work while the dead one went to Asus for replacement. When it came back, I stuck it back in and ran another 2 years before deciding to build a new rig(not because I needed it, but because I felt it was time to rebuild the drive from the ground up, and wanted to do that once). Now that old rig is still in play as a VI host and mastering machine. As for failures, spinning drives are the thing that fail most often here, followed by power supplies In the last 16 years, I've lost 1 graphics card, 2 power supplies, 1 motherboard and probably 6 spinning drives.
Old 01-09-2018, 10:23 AM
lemix's Avatar
lemix lemix is offline
I've built my DAW PC in 2013. Runs solid with ASUS P9X79 board. I think it is very similar to Albee's 6 core he was mentioning above.
I'm lucky, only experienced 2 HD fails since the late 80-ies.
In this PC I have a Samsung pro 850 SSD now ( 256GB ) 2x 2GB WD Caviars and 2 hot swap bays . I organize my bare Sata HDs many different ways , so none of them gets over stressed or near full.
I did have a part broken , the same one twice in a year !!
Corsair H100i water cooler . Avoid it !! Using a Cooler Master Hyper 212 EVO now. Fine, thanx.
My MAc mini is mid-2011 ( server, 2x 500GB 7200 rpm ) is factory with 8GB of RAM. It is no longer doing audio duties..Just looks pretty with Sierra on that 27" TB monitor
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 01-09-2018, 10:34 AM
The Weed's Avatar
The Weed The Weed is online now
Two from 2013 (See the first page of the i7 thread).
One hard drive died in 4 years. I just replaced 3 spinners with 3 Samsung 850 Pro SSDs. I plan on at least another 4 years from these 2 boxes.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 01-09-2018, 10:50 AM
uptheoctave uptheoctave is offline
2010 Cheesegrater
2015 MBP
2017 iMac 27"
James Richmond
https://www.jamesrichmond.com
2019 Mac Pro, 2022 Mac Studio Ultra
Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro.
Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com
Latest Article: Auto-Bounce for Logic Pro
Affiliate Links:
Auto-Bounce by Tom Salta
Dreamhost Web Hosting
Computer experts have you heard of this computer maker? garnoil General Discussion 3 07-07-2013 06:05 PM
Migrating to new computer and want to transfer my presets to new computer???? MASTERLINKSTUDIOS Pro Tools TDM Systems (Mac) 2 10-23-2008 10:52 AM
Digi 001 computer out to computer Cable Question dbguitar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-28-2004 03:29 PM
Desktop Computer or Network Computer? platinumx99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-07-2001 08:04 AM
question : can i copy/paste all my computer hard/soft to other computer . for a gig. sandman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 10-10-2001 08:38 PM
