Old 11-09-2011, 10:55 AM
adflaker adflaker is offline
Default Eleven Rack Problem
I'm having a very strange problem with my new 11r. It worked fine for the first couple of weeks, but all of a sudden, the UI in PT10 is messed up. The DSP works fine, and changes I make on the 11r hardware are applied, but the GUI is useless.
Screenshot:
http://dl.dropbox.com/u/3347092/Elevenrack.JPG
I can't see anything or make any changes to the rig except via the knobs/switches on the unit itself. Any advice?
Old 11-09-2011, 12:27 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Eleven Rack Problem
was it the new 11R bundle that came with the ERXP pre-installed?
If so, then you don't have the proper UI plugins. Somehow Avid overlooked the fact that the ERXP requires an installer to insert the UI plugins into the plugin folder so that the 11R window can reflect the new ERXP items. Supposedly they are working on a fix, though its been over a week since they last mentioned it, and the fix is as simple as posting the files in a compressed folder, then drag and drop to your plugin folder.
OR
Do you have the ERXP? If so, assuming you were on PT9 before, you may need to run the first part of your ERXP installer so the UI files are placed in the plugin folder.
OR
Was it working fine on PT10, then all the sudden, nothing? Maybe try a different USB port or cable. Make sure you are plugged in directly to the PC and not a HUB.
Maybe try trashing preferences and databases.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 11-09-2011, 01:05 PM
Benoni's Avatar
by the way, you will probably get more help for your issue if you post in the guitar section here on the DUC.
http://duc.avid.com/forumdisplay.php?f=33
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 11-09-2011, 02:27 PM
Thanks for your replies. I actually did get it sorted myself. It was the bundle that had the erxp installed...I installed it initially and things were fine for a couple weeks, like I said. But then today when I tried to use it, it was blank like that. I just reinstalled the erxp and things were fine, so it was just the UI plugin that was bad. Thanks again.
eleven rack - problem hydra Eleven Rack 2 10-05-2012 01:12 PM
Eleven Rack Monitor problem fustrun Eleven Rack 1 06-10-2011 06:02 PM
Eleven Rack/003 set up problem? Ph.D Eleven Rack 3 02-15-2011 03:13 AM
Eleven Rack Delay PROBLEM HELP!!!! zenabi916 Eleven Rack 2 11-06-2010 07:52 PM
Eleven Rack Problem Päng 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-18-2010 12:54 AM
