Re: Clicks only with \"Autotune\"
Hello. I'm having problems when I pass through the Autotune some choruses in my sessions. After this tuning process (not to much harder), several "clicks" appears in the new files.
These only occurs using Autotune. The rest of my files are OK. I have PT 4.1 G3 266mhz, 256 RAM, 2 HD 9 Giga, system 7.1. Regards Javier |
Re: Re: Clicks only with \"Autotune\"
You need to use the function change gain to reduce by -1 DB before using Autotune if your
files are normalised (or reach 0 DB) hope this helps. Lion |
Hey Javier — With some vocal waveforms, AutoTune can glitch if the retune speed is too fast in automatic mode, or if the curve drawn in graphical mode is too drastic (sudden change) from note to note. I always check AutoTune sections in "solo" to be sure it's working properly. Hope this helps.
Warmest Regards, Brian |
pops / clicks in Autotune? | tworooms | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 11-13-2017 07:53 PM |
Autotune | Genesis33 | Pro Tools SE and Essential (Mac) | 2 | 01-24-2011 04:30 AM |
AutoTune 7 | Limelight | VENUE Live Sound Systems | 5 | 12-29-2010 07:21 AM |
RTAS Autotune 3 + 6.9 = clicks & pops? | Blackfoot | Pro Tools TDM Systems (Mac) | 4 | 05-10-2005 12:54 AM |
Autotune bounce adds pops/clicks | Slink | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 02-10-2004 06:03 PM |
