Old 06-01-2023, 07:40 PM
smurfyou smurfyou is offline
Default Re: Finishing set-up: 5.1 / LFE question...
Originally Posted by bchrismar View Post
Hey Greg, managed to find a JBL RTA-1 and got through the mic calibration portion of setup in REW to realize I don't have a calibration file for the mic, and it doesn't seem to exist anywhere online. Any workaround for that you're aware of, or time to look for another mic?
(In the interim I used your other (dirty) methodology and mixes seem to be translating well)
Was that the mic included with the LSR series? Not sure if it was ever sold for other uses. Or maybe it's a rebadged DBX
~Will
Old 06-02-2023, 10:16 AM
Greg Malcangi Greg Malcangi is offline
… got through the mic calibration portion of setup in REW to realize I don't have a calibration file for the mic, and it doesn't seem to exist anywhere online. Any workaround for that you're aware of, or time to look for another mic?
The only workaround would be to send your mic to a calibration lab to measure and create a calibration file. TBH, it probably wouldn’t be worth it, not when there are cheap alternatives that already have a calibration file. There used to be the EMM 6 and Umik 1, both of which were around $100 and are adequate for your purposes. Not sure if they’re still available but if not, I’m sure there are cheap current equivalents.
BTW, your low pass filter (not crossover) at 120kHz, is fine, that’s what it should be for the LFE channel. As smurfyou said, you should be using bass management and this can be awkward because you want it to play the bass managed frequencies (probably 20Hz-60 or 80Hz) at parity but the LFE channel at +10dB (in-band gain). So you’ll need some bass management software/hardware that does this. Some subs have this built in and some routing/patching software does, such as the Dadman software that comes with Pro Tools and Digital Audio Denmark interfaces.
G
Old 06-02-2023, 11:23 AM
JFreak's Avatar
JFreak JFreak is offline
^^ Just because OP has old Genelecs I feel the urge to advertise less old Genelec subs. I have the 7060B and loving it (though it still beats me why it is 6.1 instead of 5.1 or 7.1) -- point being it is just no-nonsense setup and kind of set it and forget it solution you can just put to your raider.
Go Finland
Janne
Old 06-02-2023, 06:44 PM
bchrismar bchrismar is offline
Could very well be, and could be why I can't find much info on it. It was collecting dust at my other studio and can't even remember.
Old 06-02-2023, 06:45 PM
G
Thanks Greg!
  #16
Old 06-03-2023, 03:23 AM
I use a Beyer MM-1 with Smaart. You can get the individual frequency calibration file if you email them the serial number.
For absolute SPL metering however you'll need a calibrator (class 2) as well. Here's a cheap one
https://www.thomann.de/intl/digital_sound_8930b.htm
(make sure the opening matches the mic diameter. the better ones (2-300€) come with adapter inserts.
  #17
Old 06-04-2023, 03:21 PM
LDS LDS is offline
The miniDSP UMIK-2 is another option for calibration microphones. You can retrieve the specific calibration files from the miniDSP website using the serial number, and REW comes preconfigured to use it.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
  #18
Old 06-04-2023, 03:33 PM
JFreak's Avatar
My pick for RTA mic would be Audix TM1
Janne
  #19
Old 06-10-2023, 07:24 AM
dr sound's Avatar
dr sound dr sound is offline
I purchased a ISEMCON EMX 7150. It was suggested by Meyer Sound.
Bought it from here:
https://www.millerai.com/shop/p/isem...microphone-7mm
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
HTML code is On
What about finishing version 11? kava Pro Tools 11 16 02-21-2015 03:51 AM
Pro tools LE 7 not finishing loading Teddy_bob 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-31-2011 08:27 PM
Finishing up a project Anduril 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-14-2005 01:18 AM
FINISHING AGAIN! Dennis Tips & Tricks 44 02-11-2000 10:41 PM
FINISHING Dennis Tips & Tricks 4 02-01-2000 02:38 PM
