Old 01-03-2021, 06:08 AM
Ben Jenssen's Avatar
Default Re: Cannot get Studio Monitor to work w/ 11r
These are STEREO PAIR monitors. They are ment to work together. You know, Left & Right. Like in your headphones. I think you've been screwed.
Old 01-03-2021, 06:09 AM
codyjtapp codyjtapp is offline
So even with one plugged in it wouldn’t work?
Old 01-03-2021, 06:17 AM
It would have to be the one with power supply, amplifier, power switch and display like the one to the right here:
https://www.krkmusic.com/Studio-Monitors/ROKIT-8-G4
But still, you would only be able to hear either left or right of your stereo output from the Eleven, so pretty useless for anything, really.
Actually let me rephrase it another way. Is it because the 11r needs to detect connections in both outputs? If so, would getting a splitter resolve the issue?
I know monitors are typically meant to be left and right, but for this purpose, al I want to do is be able to play a guitar with something other than headphones.
Old 01-03-2021, 06:18 AM
That’s the same one I have.
  #16
Old 01-03-2021, 06:20 AM
Well, in that case, good luck with it.
I actually have better things to do.
  #17
Old 01-03-2021, 11:20 AM
Check your routing. Maybe the 11R is trying to use other outputs(SPDIF?)
  #18
Old 01-03-2021, 12:40 PM
No. This is a standard XLR balanced output, it detects nothing. And many people will run an Eleven Rack in mono mode. The rig setup supports mono deliberately to support this. That is how I largely use an Eleven Rack... driving a single high output full range stage monitor.
Again. It is likely either the cable or monitor. You have to troubleshoot with what is in front of you.. Nobody here can offer you any more advice.
  #19
Old 05-04-2021, 05:04 AM
KwakaZX10R KwakaZX10R is offline
Old thread.....but I just connected a set of Yamaha HS8's to my Eleven Rack.
They work perfectly.....XLR from Main Out L and R on the rear, into each of the monitors.
Make sure in the 11R main settings menu, volume controls, that the Main Output is not muted.
Easy to overlook, but very easy to fix!
Hope that helps
Can Studio Monitor Express & Transport act as digital monitor controller? briancares Artist Series 1 02-04-2014 05:23 AM
PT 10 Studio Monitor Old School Audio Guy Windows 0 03-07-2013 08:49 AM
studio monitor crashhak General Discussion 2 09-13-2010 08:06 PM
Studio Monitor Set up!? nfabes Tips & Tricks 2 09-13-2010 06:03 PM
Can ProTools Vocal Studio work in Pinnacle Studio 14.01.7256 Sharon Lee Taylor Pro Tools SE and Essential (Win) 2 08-28-2010 08:39 PM
