  #71
Old 03-22-2021, 02:39 PM
nedorama nedorama is offline
Default Re: Eleven Rack Compatibility with MacOS Catalina
I have the editor working in Catalina 10.15.7 on a 2013 15" MacBook Pro and on a 2019 16" MacBook Pro. Doesn't work as a Pro Tools interface, but the editor shows up as standalone and in pro tools, and way easier to edit presets.
Tip that most people know, but if not:
Take whatever higher gain amp preset you kind of like, but doesn't sound great.
  • Add the Green JRC OD Distortion in front of the amp.
  • Turn Drive down to 1.8 or lower, level 10.0, and tone to taste.
I've found this takes a lot of so-so amp sims and makes them punchier and subjectively better - similar to what a lot of people do in real life to clean up the low end and add more mids. You could mess around and add a parametric EQ in front, but this is a lot easier...
Regards,
Ned
Monkey Boy Studios
2019 16" MBP, 32GB, 1TB SSD; OSX 10.15.7; 4TB USB-C G-Tech External
Summit Audio 2BA-221, TLA-50 -->Focusrite 18i20 3rd Gen, Eleven Rack, Pro Tools 2021.3
Plugins, Virtual Instruments, and real ones
  #72
Old 03-31-2021, 04:46 AM
DonaldR DonaldR is offline
Some old Macbook Pro have SPDIF input using (mini?) Toslink connector.
I ordered a coaxial/toslink converter and I will report back. Should be able to use the Eleven Rack in Protools without digital/analog/digital conversion
  #73
Old 04-22-2021, 02:49 PM
jeffro's Avatar
jeffro jeffro is offline
Good news for us Eleven Rack users... today's driver update fixes the Pro Tools playback issue on Catalina as well as the double monitoring issue (Guitar Input isn't muted when opening a session) on macOS and Win. Took a while but happy to have this released.
linkedin
  #74
Old 04-22-2021, 05:45 PM
ac30fan's Avatar
ac30fan ac30fan is offline
Does it fix the “Error initializing MIDI...” issue?
2019 iMac 27" 5k Retina
3.6 Ghz 8-Core Intel Core i9
Mac OS 10.15.7 / 60GB RAM
UAD FW Apollo Duo (Thunderbolt Card)
PT 2021.3
Eleven Rack FW v2.00.1 / Software 1.2.14
  #75
Old 04-22-2021, 08:29 PM
Wow - this is great - thanks! Still using my Eleven Rack and appreciate this.
Regards,
Ned
Monkey Boy Studios
  #76
Old 04-23-2021, 05:52 AM
francois's Avatar
francois francois is offline
thanks
PT 2023-12 ultimate -HDX1- OSX 13.6.1- MacPro 7.1
- D-command 24- Trinnov Dmon6
  #77
Old 04-23-2021, 10:32 AM
Pingafuego Pingafuego is offline
Thanks Avid!
  #78
Old 04-23-2021, 10:41 AM
jeffro's Avatar
Is that duc.avid.com/showthread.php?t=351337? If so, let's continue this conversation there, thanks!
linkedin
  #79
Old 04-23-2021, 12:06 PM
ac30fan's Avatar
YES. And now after installing the new driver, instead of the MIDI Error, I now get this.
BTW- I don't see any new comments on the other thread where you suggest to continue conversation.
File Type: jpg Screen Shot 2021-04-23 at 2.02.37 PM.jpg (19.9 KB, 0 views)
PT 2021.3
  #80
Old 04-23-2021, 12:46 PM
Great!!!!
macOS 10.15 (Catalina) and Avid Products Avid Technical Alerts 0 10-07-2019 11:11 AM
Eleven Rack compatibility options? needled39 Eleven Rack 3 10-02-2017 11:48 PM
Eleven Rack and Ubuntu with Ardour compatibility CeeJayTheFirst Eleven Rack 1 06-15-2015 01:33 PM
Eleven Rack compatibility problems? fastnboulbous Eleven Rack 0 03-24-2011 07:08 AM
Eleven Rack in system settings of MacOS clausiii Pro Tools M-Powered (Mac) 1 12-20-2009 07:15 AM
