Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 11-14-2020, 11:39 PM
Bfearr Bfearr is offline
Default Issue Setting Tempo
This iis bizarre. I've been using Pro Tools since Version 6. I have 2019 now. I went to create a tempo and I cannot create above 125.
With the conductor icon depressed, it stops at 125bpm. I have something that I need to find the tempo for. I turned the conductor icon off, highlighted the tempo field and when I start tapping, I get an error message: "This field requires values in the range of 5.0000 and 125.0001." So, no matter what, 125 bpm is the best I can do. I think it was like 2007 when I started with Pro Tools so this is weied. Did I accidentally change a unit of measurement or something? It used to be that you kept the conductor off and set the tempo. Now, no matter what I do, 125 bpm is the highest I can set it. I'm missing something obvious. What is it?
Old 11-15-2020, 10:30 AM
Default Re: Issue Setting Tempo
I've had similar to this, but its been so long, I'm not sure I can remember the fix. Shooting from the hip, I suspect your note value might be messed up, so take a look at your time signature. Default is 4/4 which is 4 beats to a measure and typical quarter note(which might now be set to something else). If that fails, I'd head to youtube and check some tutorials on setting tempo as one of those might help you spot the problem
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Setting up Grid for Tempo changes?? rcd Pro Tools TDM Systems (Win) 2 08-02-2010 01:32 AM
Setting the tempo in 6.7 STSCRUSHER 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-21-2006 07:25 PM
Setting up tempo mastermorris Tips & Tricks 1 02-20-2006 11:31 AM
tempo setting help panicstrickin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-09-2005 09:29 PM
Setting Tempo in 6.7? MaKoRancid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-16-2004 06:31 AM
