Old 11-12-2000, 12:10 AM
GaryGarris GaryGarris is offline
Default Midi program change on the fly
Does Protools allow me to set up some sort of "macro" type system to fire off midi program changes to outboard gear while recording. Is there a way that I can do anything like this without a midicontroler pedal.
Old 11-12-2000, 08:38 AM
DigiTechSupt's Avatar
Default Re: Midi program change on the fly
Gary,
1 way to do this would be to record the program changes to a specific midi channel. When you start playback that midi track would playback or send the program changes for you while you record into another midi track.
Check out pages 207-211 in the pro tools reference guide for the specifics.
B Carter
Digidesign
Avid Audio Tech Support
Support FAQ
Old 11-12-2000, 02:55 PM
Compression Records Compression Records is offline
Mr. Carter,
Does 5.1 comply with the now industry-standard insertion of MIDI events, including program changes and controllers? The procedure you are suggesting is quite cumbersome and limited for the more advanced programmers. Thanks for your support.
Marco Marinangeli
Magelic Productions, Inc.
Compression Records
http://www.compressionrecords.com
Marco Marinangeli
Compression Records
Old 11-14-2000, 08:58 AM
What I am actually trying to do is while I'm recording a show use protools to send off program changes. The trick is they don't occur at the same Timecode point everytime. I basically want to do the same thing that a midi guitar pedal does and switch outboard gear. Thanks
Old 11-14-2000, 10:08 AM
Gary - you can send the program change on the fly without having to record.
Marco, with the addition of the midi event list you can now insert program changes, controllers ect. in PT 5.1
B Carter
Digidesign
Support FAQ
Old 11-16-2000, 10:20 AM
Unfortunatly I need to be recording while sending the program change.
My situation is this:
I am recording 8 inputs into Protools for 60 plus minutes of a church service. There are 6 services that are identical each week. The music changes each week both in content and style but stays the same for all 6 recordings. I would love to change outboard gear by hitting a pre configured macro or something like that.
Thanks
Midi Program Change Problem tony_cb Pro Tools 10 1 05-16-2013 04:05 AM
Program change via MIDI on PT7 JSPurcell Tips & Tricks 1 09-12-2010 11:19 PM
problem with midi program change Riccardo Corbari Pro Tools TDM Systems (Mac) 9 02-22-2006 09:06 AM
midi program change porkipine MIDI 3 05-14-2005 04:52 AM
Midi Program Change Bug? Nocturnal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-28-2002 05:54 PM
