Old 09-01-2019, 08:09 PM
ZdonTheRapper ZdonTheRapper is offline
Default XPand Downloaded and Installed but not showing up in plugins.
XPand Downloaded and Installed but not showing up in plugins. Please help, idk whats going on.
Old 09-02-2019, 05:02 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: XPand Downloaded and Installed but not showing up in plugins.
Installed the latest version 64 bit in a 32 bit system?
Chris
Producer, Engineer,
www.ukmastering.com
Old 09-02-2019, 05:22 AM
Originally Posted by crizdee View Post
Chris
That's only part of the op's problem if his profile is right. Seems he's trying to use PT10 on OSX 10.10.5 which we all know wont work right (blank inserts until you hover over them, etc.).
Old 09-09-2019, 03:08 PM
Chris
Crizdee, I apologize, I didn't include a lot of info. I updated my system specs in my signature. I switched from a Mac to Windows, so rn I'm using Windows 10 Pro 64-bit. And I think it might be that I'm downloading a version of XPand that is for a future version of ProTools. Cuz I'm downloading XPand!2 2018.10, and I think that might only be for ProTools 2018.1 or newer. I have no idea though. I have a couple other downloads available that I might need to try redownloading. I'll include screenshots. If you could instruct me which ones to download for my system and version of ProTools it would be much appreciated. Thanks again.
Computer: Dell Latitude E6410
Processor: Intel Core i5 M520
Speed: 2.40Ghz
RAM: 4GB
Hard Drive: 320 GB
OS: Windows 10 Pro 64-bit
Pro Tools Version: 10.3.10 using ASIO4ALL-V2
ILok: ILok 3
Old 09-09-2019, 03:13 PM
I apologize, I forgot to update my system specs. I'm on Windows 10 Pro 64-bit rn. I switched from a Mac. I think the issue might be that I'm downloading a version of XPand that's for a newer version of ProTools. I downloaded XPand!2 2018.10 which I think might only be for ProTools 2018.1 or newer. I have a couple other downloads available as far as instruments go. I'll include screenshots. If you could inform me of which ones I should try that would be super helpful, thanks again.
Speed: 2.40Ghz
RAM: 4GB
Hard Drive: 320 GB
ILok: ILok 3
Old 09-16-2019, 02:46 PM
cruisemates cruisemates is offline
I have the same problem - I have PT 10 and downloaded the xpand2 download from "My Avid" but I cannot install it. I tried to but it does not seem to come up.
One trick I heard is to install it while ProTools is NOT running. Also - make sure the sounds are in C:/Program Files/Digidesign/ - but I have not tried this yet. I started a similar thread last month - not sure anyone replied, however.
- but the second mouse gets the cheese
Old 09-17-2019, 03:36 AM
You NEVER want to install plugins while PT is running. Also when installing let the installer put stuff wherever it wants to install things and then you may be able to move samples around later but first make sure everything works okay before you do that. And make sure you're installing s/w as admin.
Old 09-19-2019, 02:41 PM
And thanks for your comments -
I am just wondering if anyone remembers having to move any files after an installation of XPand2 in PT 10. And from where to where?
Downloaded Pro Tools Make Whole V2 - to Update to 12.4 Not showing in Ilok ccvastudio Licensing & Accounts 3 02-22-2018 10:35 PM
Free plugins are downloaded from where? Maurixio Getting Started 1 09-01-2013 02:06 AM
should I have installed xpand etc with PT8 nelsonmay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-23-2009 01:47 AM
Downloaded cs6, installed as cs5 bashville Pro Tools TDM Systems (Mac) 4 07-27-2008 10:06 AM
Installed Plug's not showing up??? kitana_one 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-19-2005 09:14 AM
