Help with Reverb on Vocals
Hello Folks,
I am a true newbie when it comes to tracking vocals ... been used to creating EDM Music without vocals at all ... Now I am about to use some vocals in my tracks .... One thing I would really like to know .... how can I get that perfect reverb sound on vocals that is on most commercial tracks ... I know one thing, it is better to use reverb as a send rather than an insert effect .... What are the good settings for vocals using any standard Reverb plugin you guys use, whether stock or let's say any Waves Plugin ... can you provide me with a preset ? Thanks
System Details: iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz Macbook M2 Pro macOS 14.4.1 Pro Tools 2024.3.1 Logic Pro X Reason 12 UA Apollo 8p Apogee Thunderbridge/Apogee Symphony I/O 2x6 Eleven Rack/Focusrite ISA Two/Onyx 1640i UAD Satellite Quad MOOG Mother 32 Nektar Panorama P1 Axiom AIR 49/Axiom 49/Yamaha P35 Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e Genelec 8040b/Yamaha HS80s/M-Audio BX5a Beats Solo/Shure SRH1840/Slate VMS https://open.spotify.com/artist/7KfV..._branch=1&nd=1 |
Re: Help with Reverb on Vocals
Plenty of presets come with whatever reverb plugin you choose to buy. but few things you want to keep in mind and experiment:
1) pre-delay. if you don't have it on your lead vocal, it will get buried under the reverb and you keep pushing the volume up. you don't need much, generally speaking somewhere between 25-50ms should be perfect, depending on the material. 2) reverb length. don't overdo it. for a fast song keep it under one second and for a slower one, do not let yourself be fooled with anything longer than 1.7sec -- might sound nice to begin with, but most likely gives you trouble somewhere else. then again, these are only general guidelines, not strict rules. 3) two small reverbs might be more than one huge hall. try very short reverb combined with slightly longer plate. or something else. however these need to be two different algorithms, otherwise you would benefit from delay more than a reverb. 4) oh, did I already mention a delay? sometimes delay is better "reverb" than anything else. 5) remember, you're trying to make the vocal sound nicer, not push it back behind the drum kit... Good luck :)
can you try to elaborate a little more on the 3rd point ?? I didn't quite get it on how to do it technically ...
You can do it either in parallel or in serial; for example:
parallel) you have two sends and two auxes. sendA to aux1 drives short reverb and sendB to aux2 drives long reverb. mix to taste. serial) you have one send and one aux just like using single reverb. you have short reverb in insert slot 1 and long reverb on insert slot 2, or vice versa. use different MIX percentages on both reverbs to get it right. This is art more than science :)
Perfect !! Thank you !! :)
Couple more more things you may want to try;
- insert a de-esser before your reverb plug in - roll off some top end on the rev return - experiment with compression on the rev return
"Don't look; listen!" At work; 2013 27" iMac/i5/2.9GHz/8GB, OSX 10.8.5, PT 10.3.6 At home; Custom Made Mac (Hackintosh) i7 (3770 "Ivy Bridge")/3.4GHz/32GB@2400MHz, Samsung SSD 840 EVO 250GB System Drive, Samsung SSD 750 EVO 250GB Audio Drive, OSX 10.10.5, PT 12.8.1 |
Good tips above, so I won't go there.
But, keep in mind that if you send something awful into any reverb, there's a good chance you're getting something awful in return (pun intended). Good, clean vocal tracks are important. You can't "fix it in the mix" by using reverb. Just sayin'...
De-Essing, Compression and EQ on the AUX Reverb Channel ?
Yep, most processing before the reverb, some after. You will know what you like once you experiment...
Another tip, you could also create 2 aux tracks...one with Reverb A and one with Reverb B...and then send from Aux A to Aux B...mix to taste. This can layer a reverb effect nicely. Reverberate from Liquidsonics allows you to actually have 2 different reverbs simultaneously on one insert that you can mix together in any way you wish, or even automate. Clever.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
Recording vocals while monitoring with reverb | Pat D. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-29-2016 06:26 AM |
Reverb on vocals | felix822 | Post - Surround - Video | 7 | 05-11-2011 06:16 AM |
Reverb on vocals | 14choirs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 06-25-2008 07:41 AM |
Reverb swell into vocals... | Ssaidvox1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-09-2003 08:49 AM |
Reverb settings on vocals | sonicprod1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-21-2002 12:57 AM |
