Old 05-01-2020, 07:00 PM
studiojb studiojb is offline
Default Should I deactivate plugs while over dubbing?
With delay compensation active, If I'm overdubbing, do I need to deactivate any latency causing plugins on the the other tracks I'm playing along to?
I already do this to anything on the master buss. I just don't know about the other tracks I'm playing along to.
I don't track with any plugs on the recording track.
Old 05-04-2020, 10:52 AM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Default Re: Should I deactivate plugs while over dubbing?
I usually freeze everything before overdubbing if the session is big, so I can use a smaller buffer size and prevent delays.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 05-05-2020, 09:18 PM
I have done this, as well as disabled any plugs with latency. I just didn't know if I had to? Also, does buffer setting come into play if I'm not using a VI or any effects, and monitoring through an Apollo? I didn't think so but now I'm not sure.
Deactivate Plugins when Scrubbing spock999 Pro Tools 2018 2 09-10-2018 12:21 PM
Need to deactivate surround I/O in PT9// onepercentfree Pro Tools TDM Systems (Mac) 0 11-23-2010 10:37 AM
Need to deactivate surround I/O in PT9// onepercentfree Post - Surround - Video 0 11-22-2010 11:21 AM
Deactivate all plugins? Beauchampy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-22-2006 11:19 AM
Deactivate TDM plugins eurosurfer Pro Tools TDM Systems (Mac) 2 09-03-2001 08:01 AM
