Old 05-29-2018, 04:38 PM
vudoo vudoo is offline
Default S6 M10 v3.5 works with PT ultimate 2018.4 ?
Hi there,
I just updated my PT to 2018.4 and my S6 main module does not work work anymore, I/m on S6 M10 v 3.5, is this normal ?
Thanks
Old 05-29-2018, 06:37 PM
its2loud its2loud is offline
Default Re: S6 M10 v3.5 works with PT ultimate 2018.4 ?
Upgrade the S6 software
Old 05-30-2018, 10:46 AM
creativecontrol's Avatar
creativecontrol creativecontrol is online now
Please also look at the following S6 Knowledge Base article under DOWNLOADS. If you are using a newer version of Pro Tools with an older version of S6 you need to manually install the appset files.
http://avid.force.com/pkb/articles/e...vid-S6-Support
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-30-2018, 03:06 PM
Installing the appset fixed the problem...thx Jeff
Massenburg Design Works MDWEQ5 crahes PTHD 2018.1 TrackerLe Pro Tools 2018 75 06-20-2019 04:51 PM
PT 2018.4 Ultimate bugs ? Glazik Pro Tools 2018 26 07-10-2018 11:56 PM
Latency with Pro Tools Ultimate vs. regular Pro tools 2018 DualCoreX2 macOS 5 04-25-2018 08:17 AM
Pro Tools Ultimate 2018.4 GUI offset by tabs error Mike Ritchie Pro Tools 2018 2 04-10-2018 03:49 PM
Pro Tools 8 LE, Windows 7 Ultimate (WORKS FINE) Can i enable Previous Versions (VSS)? Toonyan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-13-2011 02:11 AM
